An interesting proposal from the FIA for 2008. A rear wing that creates a tow and improves the downforce of the following car.
http://www.fia.com/mediacentre/Press_Re ... 05-01.html
http://www.fia.com/resources/images/178 ... raphic.jpg
I suppose the obvious "problem" to watch for - if the wing is too good at doing it's job, making overtaking too easy - then I can see all sorts of other problems arising, perhaps more desperate defending.
A careful balancing act required.
I don't quite get how it creates a tow as the wake will be quite smooth.........hmmmm
EDIT: I just read the whole article - a shameless and pointless plug at the end by an AMD execcutive - really they should be above that sort of thing
