Slip angle and power
Erunanethiel
Erunanethiel
When you are in a turn and rear have lost grip ( too much slip angle) if I put more power on the the rear tires (rwd car)
Will the slip angle increase? Can power increase the slip angle?
Jersey Tom
Jersey Tom
167
Re: Slip angle and power
Is this basically asking.. if you don't have much rear grip on a RWD car and mash the throttle, will you spin out? Sure.
SectorOne
If you oversteer through on throttle, you let off to save it.
If you oversteer through for example lift off oversteer you can add throttle to move weight on the rears.
Erunanethiel
Erunanethiel
Jersey Tom wrote:Is this baslically asking.. if you slip 't have much rear grip on a RWD car and mash thpower youle, will you spin out? Sure.
Yeah but does that change the slip Angle? Does what slip you have change your longitional grip? (how much power you can put down)
flynfrog
Yes. Your tires can only provide so much force. Image
flynfrog
It looks more like this
DaveKillens
DaveKillens
34
Erunanethiel wrote:When you are in a turn and rear have lost grip ( too much slip angle) if I put more power on the the rear tires (rwd car)
If you have exceeded the point where the slip angle is at it's maximum, then it drops off quite rapidly. Basically, the back end is coming around. The usual correction is to lift the throttle, turn into the spin, and pray that you can collect it back. But if you apply power, woopsie dooo.
Power does not increase the slip angle, that is determined by the tires, the lateral load, and grip available. In rally cars and the domestic sedan, the tire slip angle is wide and generous. But in a Formula One tire, because they are designed for incredible grip on asphalt, the slip angle is incredibly fine, less than 6 degrees. Once past that point, they fall off the cliff.
http://www.f1technical.net/forum/viewto ... f=1&t=5967
Erunanethiel
Erunanethiel
So I should change my question ( because I think I found a sitiuation to answer my question perfectly).
I have rear wheel drive car that doesnt have much power. For example gt86.
If I take off the Prius tires and put some proper ( michelin pilot cups? Maybe) now my gt86 cant spin its tires off the line due to the lack of power. But in a corner, if I start the oversteer by transfering weight (the rear wheels are sliding, too much slip angle) will I be able to balance the car or make it oversteer more on throttle? ( has the longitional grip decrease?)
Lycoming
Lycoming
106
The more lateral force you're getting from the tire contact patch, the less longitudinal force you will be able to get out of it. But forward acceleration will transfer more weight onto the rear wheels, which will allow you to generate more longitudinal and lateral force. Whether or not that results in you spinning out requires more details.
Erunanethiel
Erunanethiel
Lycoming wrote:The more lateral force you're getting from the tire contact patch, the less longitudinal force you will be able to get out of it. But forward acceleration will transfer more weight onto the rear wheels, which will allow you to generate more longitudinal and lateral force. Whether or not that results in you spinning out requires more details.
How about like if I am over the slip angle which the tire gives its top lateral performance, is it now easier for me to spin the tires more even tho I dont have much power? I can keep the car sliding all day long, once I started it through weight shift?
DaveKillens
DaveKillens
34
It sounds like you're thinking of drifting. I really hope you don't try that on the street.
Erunanethiel
Erunanethiel
DaveKillens wrote:It sounds like you're thinking of drifting. I really hope you don't try that on the street.
Oh yeah I drift everywhere :mrgreen: :mrgreen:
Am I not brilliant? =D> =D>
Erunanethiel
Erunanethiel
So lets stay on the subject.
Is there a correlation between slip angle (lateral grip) and slip ratio (longitudional grip)?
Erunanethiel
Erunanethiel
Nobody knows?
671
Erunanethiel wrote:So lets stay on the subject.
how could there not be ?
IIRC such an effect has been presented in engineering texts
eg in the context of mechanisms to de-friction or de-stiction elements in mechanical handling/motion applications
a rotating bearer will allow low friction translational motion of a load in the direction of the rotational axis (and vice-versa)
there is a range of rear axle torques in which rear slip angles reduce and front slip angles increase (relative to other ranges)
this range is the drifting range, the term drifting (short for 4-wheel drifting) emerging in the 1930s
nowadays drifting has become a meaningless term relating to operation beyond this range of torques
where only the driver knows whether there is significant front slip hidden by armloads of countersteer/opposite lock
99% of the time there is not, little skill is involved, and it is only what was in earlier times called a powerslide
ie it looks good but the (apex) speed is low
the way to get into the drifting range is to go faster into the corner
maybe you are doing this already ?
