Some 2T questions.
Zynerji
109
Some 2T questions.
So, just coming up to speed on the 2T tech as F1 talks of moving into that direction, but a few things are unclear to me after reading up.
1. Is it necessary to feed the air through the crankcase, or could it be sent from outside? Does a VLIM make sense for 2T?
2. I see lots of roller bearing cranks in the snowmobile world. It's that a 2T thing? Why?
3. If the expansion exhaust is used for scavenging, is this required for a turbo setup? Possible VLEM with movable folded horn?
I have a few more, but would like to hear about these first.
Thanks!
622
Re: Some 2T questions.
Zynerji wrote:
12 Apr 2020, 19:29
normally/traditionally
1 NA must use crankcase induction - Boosted avoids using crankcase
2 roller bearings used to minimise oil need as oil is in petroil or is pumped oil ending after 1 pass in total loss
3 tuned length exhaust action is not necessary/desirable
btw a few million 2T European-normal-sized road cars were sold c 1930s - 1970s (almost all DKW derived)
Big Tea
99
Tommy Cookers wrote:
12 Apr 2020, 20:39
Zynerji wrote:
12 Apr 2020, 19:29
A friend had a Wartberg (is it Knight????) 3 cyl 2t it sounded brill and did not go too bad after a bit of modding.
I seem to remember it being red hot after a run and steaming like a train
Edit, just googled it, which I should have don in the first place, apparently it was Wartburg 353 in E Germany
