Maserati MC20 (First TJI roadcar??)
Holm86
245
Maserati just unveiled their new V6 engine to power the MC20 supercar, it features F1 derived pre chamber combustion
Is this the first roadcar to use TJI combustion??
https://www.thedrive.com/news/34552/mas ... mZKPKAHL0s
_cerber1
239
Re: Maserati MC20 (First TJI roadcar??)
Mercedes-AMG Project One?
Holm86
245
_cerber1 wrote:
02 Jul 2020, 15:51
But when will Project One hit the road??
And did Mercedes have TJI on the early version of the engines which the P-One is based upon??
strad
117
I don't see anything new around the TJI. What is it that's earth shattering about this?
Sir Stirling Moss
Cbckly917
Cbckly917
It may pre-date the AMG One as the first car with a TJI/pre-chamber ignition system. It will all depend on when the MC20 launches vs the AMG.
Holm86
245
strad wrote:
02 Jul 2020, 18:50
Nothing earth shattering? Just thought it was interesting
DINO3
DINO3
Pre combustion chambers have been in use since 1930’s , nothing new 🤷🏼...
TNTHead
DINO3 wrote:
02 Jul 2020, 22:45
Yeah, like almost all diesel engines in passenger cars before the volkswagen tdi diesel engines came out have pre combustion chambers, or industry diesel before common rail came out all over the globe
Holm86
245
Yes in Diesel engines, it's not commonly used in petrol engines.
564
Yes TJI is a potentially game-changing technology. There is nothing that can match its combination of ultra-lean burn with rapid and complete combustion.
63l8qrrfy6
63l8qrrfy6
368
Pre chamber ignition has been in use in industrial large bore natural gas (SI) engines long before F1 for similar reasons - to address slow combustion speed given the size of the bore.
VARIANT | one
From the spy shots of this thing, it looks to me a lot more compact and "4C like" than a lot of these giant surfboard supercars. I like that. :wink:
NoDivergence
NoDivergence
50
Mudflap wrote:
07 Jul 2020, 02:12
It's also been used in liquid fuel rocket engines long before that. That said, different application, different technical difficulties.
Holm86
245
564
Found this quote from an earlier paper on TJI. It explains the benefit of the extra spark plug external to the pre-chamber.
Additionally, a new concept in “Spark Assisted Jet Ignition” combustion was proposed to enable stoichiometric boosted high load operation, where the jet igniter is coupled with a conventional spark plug. With this concept, some of the main chamber charge is consumed first using the conventional spark ignition flame propagation process, with the remaining charge consumed by the jet ignition process Figure 14. Two possible configurations for “Spark Assisted Jet Ignition”, where some of the main chamber charge is consumed using the conventional spark ignition flame propagation process and the remainder using jet ignition combustion in order to increase the burn duration and reduce the heat release at stoichiometric boosted high loads.
A Gasoline Fueled Pre-Chamber Jet Ignition Combustion System at Unthrottled Conditions
Attard et al / SAE Int. J. Engines / Volume 5, Issue 2(May 2012) 327
