a famous marquis that produced one of the best three ever engine sounds in GP racing.
saviour stivala
saviour stivala
A breath of fresh air this morning. The famous smallest piston ever used in GP racing is to be re-created and brought back to live thanks to the famous extended family and a privet restorer.
Steven
Owner
Re: a famous marquis that produced one of the best three ever engine sounds in GP racing.
What are you talking about? Link?
And is this related to F1, or should this move to automotive tech?
saviour stivala
saviour stivala
Autosport.com and about another dozen F1 sites. 3-4 days ago. ‘’Three BRM V16 F1 car continuation to be build – historics’’.
For those interested in engine Specification.
Cylinders. V16.
Bore. 49.5mm.
Stroke. 48.3mm.
Stroke/bore ratio. 0.98:1.
Capacity. 1,487cc.
Compression ratio. 7.5:1.
Connecting rod length. 104.8mm.
Rod/crank radius ratio. 4.3:1.
Main bearing journal diameter. 58.4mm.
Rod journal diameter. 38.1mm.
Inlet valve diameter (1 valve). 31.8mm.
Exhaust valve diameter (1 valve). 37.8mm.
Inlet pressure. 4.85Atm.
Engine weight. 238kg.
Peak power. 430bhp @ 11,000rpm.
Piston speed (corrected). 17.6m/s.
Engine bhp per litre. 289.1bhp per litre.
Engine weight per bhp. 0.55kg per bhp.
622
three V16 B.R.M. 1950 F1 cars are to be made from the original drawings still kept by the Owen family
it being the 70th anniversary of the founding of the BRM team
unless the OP has in mind some other GP car having pistons smaller than the 47.8 mm pistons of the BRM
OO7
OO7
171
saviour stivala wrote:
04 Nov 2020, 14:59
I was pretty happy to learn that as well! One of the best sounding cars ever to have raced. =D>
Ringleheim
Ringleheim
A famous *MARQUE*
saviour stivala
saviour stivala
The 135 degree vee angle even firing V16 had an unique ignition system. Firing each cylinder through a small aperture was a 14mm Lodge spark-plug, spark generated by battery powered coil ignition system. A 4-cylinder distributor was driven from the front of each of the 4 cams and supplied with its own spark coil. Each of the 4 distributors had 3 sets of points, one made contact, one broke-it and one (manually selected) gave a retard timing for starting the engine.
saviour stivala
saviour stivala
OO7 wrote:
07 Nov 2020, 16:42
04 Nov 2020, 14:59
The BRM V16 produced an engine sound that stands on all ever engine sounds.
J.A.W.
J.A.W.
109
Tommy Cookers wrote:
07 Nov 2020, 16:15
Honda GP engines ran smaller pistons, & actually won FIM World Championships...
saviour stivala
saviour stivala
J.A.W. wrote:
08 Nov 2020, 00:12
07 Nov 2020, 16:15
FIM stands for motocross world championship and not formula one. As far as I know, and I stand to be corrected. The smallest diameter pistons Honda ever used in their F1 engines were those used on the RA272E 1.5-LITRE V12 of 1965 having a diameter of 58.1mm and paired with a stroke of 47mm for a cylinder capacity of 124.583cc. On the other hand. The BRM type 15 1.5-LITRE V16 of 1951 used 49.5mm pistons paired with a stroke of 48.3mm for a cylinder capacity of 92.967cc.
622
J.A.W. wrote:
08 Nov 2020, 00:12
07 Nov 2020, 16:15
what a lot of smartarses !!!
the smallest GP motorcycle pistons were of course the (50cc) Suzuki twin's 32.5 mm
unless we count the never-raced 50cc GP Suzuki 3 cylinder's 28 mm
or the never-raced 50cc Fitz-Ray 4 cylinder's 25.15 mm
(Honda have never used pistons smaller than the 33 mm of the 1962 RC112/1963 RC113)
see the site classic50racingclub.co.uk
saviour stivala has again used the computer clock 'time travel' fiddle to retro-outmanoeuvre another's post
saviour stivala
saviour stivala
11 Nov 2020, 18:48
J.A.W. wrote:
08 Nov 2020, 00:12
07 Nov 2020, 16:15
You are totally mistaken. i did no such thing. the time and date are factual.
Big Tea
99
11 Nov 2020, 18:48
J.A.W. wrote:
08 Nov 2020, 00:12
07 Nov 2020, 16:15
Anyone interested in small pistons and bikes, this is worth a read
https://www.telegraph.co.uk/cars/featur ... rand-prix/
It was 34mm x 27.4mm, but ran 22,000rpm and an eight-speed gearbox in 1964
564
11 Nov 2020, 18:48
If only he would time travel and fix the title of this thread.
strad
117
the BRM V16 indeed sounds sweet. I tried to post a couple of sound files but they wouldn't play on this site. :(
HTTP://www.stradsplace.com/SOUNDS/brm_v16.mp3
If you click on the link a player opens but doesn't play BUT if you click on the three dots on the right side and hit download you can open the file. Got a couple of others but it's the same hassle.
Something to do with W10 no doubt.
Sir Stirling Moss
