Underside for maximum downforce?
Uwe
Uwe
If there is no tehnical rules what is best theoretical design of underside for get maximum downforce for given car?
here is some solutions:
Greg Locock
Greg Locock
233
Re: Underside for maximum downforce?
You need to buy a copy of Katz
Zynerji
109
Greg Locock wrote:
18 Dec 2020, 22:44
I think i have that somewhere... :lol:
the EDGE
the EDGE
67
I believe Venturi tunnels with full side skirts would be the best possible solution
The design maximised the ground effect to a level I don’t think has ever been beat since they were banned in F1
Uwe
Uwe
the EDGE wrote:
18 Dec 2020, 22:53
I dont know how to desing entry part,flat(left 1 picture) or lifted up(left 2 picture),and how long narrow section must be?
And do narrow section design flat or in curve line..?
Do F1 2022 has venturi tunnel shape?
the EDGE
the EDGE
67
Uwe wrote:
18 Dec 2020, 23:05
the EDGE wrote:
18 Dec 2020, 22:53
Well I’m no expert but I’d say the second on the left or top right comb would be the closet diagram of a Venturi tunnel
They scoop at the front, compress, then expand for as much or the distance as you need
The skirts would be the full length and and close to ground you can get them
Greg Locock
Greg Locock
233
you could run experiments in microcfd http://microcfd.com/2d.htm to find out whether the traditional venturi shape is optimal, and how much it is affected by the nose and upper body.
Uwe
Uwe
Greg Locock wrote:
18 Dec 2020, 23:18
I dont know work with CFD.
Be worth looking at history too. The sports car prototypes often struggled to get the expected performance with growing diffuser size. Took them a while to figure out how to get it all working. Bigger doesn't automatically mean better.
Zynerji
109
Just_a_fan wrote:
19 Dec 2020, 01:45
I believe the trick they found was increasing the mass airflow helped most.
toraabe
toraabe
Zynerji wrote:
19 Dec 2020, 07:14
Just_a_fan wrote:
19 Dec 2020, 01:45
Ross Brawn and John Piper who designed the xjr14 came up with a very clever idea on how to seal the floor. They put a flap between the front and rear tyres. This can be traced to the new f1 cars on sealing the floor. Same idea...
Uwe
Uwe
left picture has short narrow section,right has long narrow section..
Narrow section I call part of underside wich is close to the ground..
Which option produce max downforce?
Stu
Uwe wrote:
18 Dec 2020, 14:15
https://images.pexels.com/photos/622541 ... =650&w=940
You need to think in three dimensions and (almost) treat the front of the car as a separate entity to the rear (but not at the expense of the rear!).
The position and shape/size of the ‘throat’ will determine the sensitivity of the downforce generated and the CoP location.
The design of the inlet will determine the potential of the system, and the outlet the efficiency of the system.
Uwe
Uwe
Stu wrote:
19 Dec 2020, 10:46
Does throat section must be curved or straight?
Wherse is center of pressure of underside,at throat?
So if I want to load front and back part equal,then I must put throat in the middle?
toraabe
toraabe
If you look at the Mercedes c11 downforce, it was stable and didn't shift when braking or turning.
