Every auto racing tournaments in the world steering linear actuator types
theriusDR3
theriusDR3
Here are the list of all auto racing tournaments in the world steering linear actuator types:
FIA Formula 1 World Championship - Hydraulic power steering rack and pinion (not sure about it)
FIA Formula 2 Championship - Manual steering rack and pinion
FIA Formula 3 Championship - Manual steering rack and pinion
Porsche Mobil 1 Supercup - Electromechanical power steering rack and pinion (not sure about it)
Deutsche Tourenwagen Masters (coupe silhouette -> sedan silhouette -> coupe silhouette -> coupe Class 1 silhouette) - Power-assisted steering rack and pinion
IndyCar Series - Variable-assisted manual steering rack and pinion
NASCAR Cup Series - Power with recirculating ball
NASCAR Xfinity Series - Power with recirculating ball
NASCAR Truck Series - Power with recirculating ball
FIA World Endurance Championship - Full-power steering rack and pinion (all classes - not sure about it)
FIA World Rally Championship - Power-assisted rack and pinion
Australian Supercars Championship - Power assisted rack and pinion
Japanese Super GT Series - Power-assisted steering rack and pinion (GT500) and various (GT300 - not sure about it)
Japanese Super Formula Championship - Electric power steering rack and pinion
FIA World Touring Car Championship later World Touring Car Cup (WTCR) - Electrical power-assisted rack and pinion steering
Any additions? Correct me if i wrong!
Re: Every auto racing tournaments in the world steering linear actuator types
DTM is switching to full electric servo fly-by-wire steering.
622
PhillipM wrote:
16 May 2021, 13:40
please explain the above seemingly remarkable statement
aircraft control surface actuators categorised as 'all-electric' are of course internally hydraulic
'fly-by-wire' means digital numeric processing in the control loop - and no alternative load path (ie manual reversion)
hUirEYExbN
I wonder if the WRC is thinking of heading the steer-by-wire route in some future regulation change.
https://dirtfish.com/rally/wrc/rally-sp ... re-fiesta/
Ieatmytoastraw
Ieatmytoastraw
Tommy Cookers wrote:
16 May 2021, 14:25
PhillipM wrote:
16 May 2021, 13:40
It's called Space Drive, https://the-race.com/touring-car/why-a- ... ional-car/
Its apparently an amazingly good system, with excellent steering feedback, massive redudancy. Its going to be a game changer for road car packaging in the future.
622
Ieatmytoastraw wrote:
16 May 2021, 15:11
well I thank you ....
presumably using its driver-aid potential will be prohibited in racing
(existing) PAS hides low grip from the driver
handily for the track this SD would eliminate so-called bump steer
whatever happened to the Citroen SM ?
Tim.Wright
330
16 May 2021, 18:00
16 May 2021, 15:11
Bumpsteer is purely kinematic, it has nothing to do with the power steering. There is a little cross compliance from the torsion bar but that's another thing completely.
622
Tim.Wright wrote:
16 May 2021, 18:18
exactly ..... unlike existing steering systems .....
the Space Drive won't have a steering linkage layout that's kinematically conflicted with the suspension linkage layout
Tim.Wright
330
What exactly is the conflict?
622
Tim.Wright wrote:
16 May 2021, 19:53
I don't know
I thought the matter under discussion was the Space Drive - not conventional steering systems
Greg Locock
Greg Locock
233
Tim.Wright
330
17 May 2021, 01:06
You were explaining to us how steer by wire gets eliminates bumpsteer and kinematic constraints present in conventional systems. Neither of these assertions seem correct to me.
622
Tim.Wright wrote:
17 May 2021, 18:19
'full electric servo fly-by-wire' steering doesn't need any steering linkages (ok the DTM/WRC version of SD does)
and FESFBW steering ....
doesn't need to be truly continuous (most PAS isn't)
would be safer than most PAS
sincere question - why steer the front wheels ? (ok why not ?)
Tim.Wright
330
18 May 2021, 13:59
Tim.Wright wrote:
17 May 2021, 18:19
Drive by wire still have steering linkages. Bumpsteer is still present but it's a desired characeristic. You can't get rid of it with a SBW system anyway.
Steering the rear wheels is dynamically unstable. It's also subjectively terrible - the car feels like it over-rotates before entering the curve and each steering input causes a first reaction of the lateral acceleration in the opposite direction before swinging back. That's, btw, part of the reason why it's dnyamically unstable.
622
Tim.Wright wrote:
18 May 2021, 18:19
Drive by wire still have steering linkages.....
not if there's rotary actuators (working on the steering axes eg steering struts)
so 2 actuators (or maybe 4)
