Aerodynamic balance biased towards inside or outside tire?
Joe7218
Joe7218
Hi all,
Just wondering if during any given cornering situation, would you want the aerodynamic balance to be closer towards the inside pair of wheels or outside?
Intuitively I would think you would want to give more downforce to the inside tires; as those are the unloaded tires during a corner is this correct?
I am thinking about say, splitting the drs flap in half, and then having each 'flap' open or close by varying amounts to shift the aero balance left and right (ignoring the foward and back shift this would also cause, would need a similar mechanism on the front wing or something). Would this have any unwanted downsides if shifting balance towards inside side of car?
Thanks!
EvilPhil II
EvilPhil II
Re: Aerodynamic balance biased towards inside or outside tire?
Joe7218 wrote:
17 Aug 2021, 13:32
Hi all,
Thanks!
I am not an engineer, but stick your hand out the side of a car window (when safe to do so). I am guessing the inside would cause more drag and therefore more rotation.
UlleGulle
UlleGulle
Yeah. And It's been done.
Pagani Huayra raises it's flaps on the inside to increase downforce on the unloaded tires and prevent roll.
Zenvo has a solution where they flip the whole back wing to achive the same thing.
Stu
This looks more like a gimmick than anything truly useful.
The wing is mounted to the body, so any forces are applied to the body, if you wanted to actively change individual wheel loading the wing would need to be split and have at least one mount attached to the wheel-hub.
Joe7218
Joe7218
Would the benefit of increased load on the inside tires outweighs the reduction in total downforce that this would cause?
I guess it would be determined by the corner type and if you are limited by power or grip.
Stu wrote:
17 Aug 2021, 14:39
This is an interesting thought, would the forces not travel through the body and suspension system into the tyres though?
Of course unsprung aero would always be more efficient I guess.
AnthonyG
38
Ferrari used an assymetric rear wing on their F2007 or F2008 for the Monza race.
I'm struggling to find a picture of it however.
Big Tea
99
UlleGulle wrote:
17 Aug 2021, 13:56
https://thumbor.forbes.com/thumbor/960x ... it%3Dscale
What about the other side of the coin? pop out drag brake on the inside corner?
Xwang
Xwang
29
Stu wrote:
17 Aug 2021, 14:39
I do not agree.
In any case an asymmetric aerodynamic body would give a resultant force whose aerodynamic centre would not be in the car's symmetry plane.
So it the aerodynamic is made to create more downforce on a side of the car, the wheels on the opposite sides of each axle will receive corresponding different loads.
It's the same principle which is used in the longitudinal case to balance the aerodynamic load between front and rear axle and it does not require to attach the wing to the wheel hub.
Asymmetric aerodynamic setups have been used in all speedway races since ages (if allowed by rules).
UlleGulle wrote:
17 Aug 2021, 13:56
That wing will cause a small reduction in downforce but it will give an increased lateral force albeit likely quite small.
Remember that lift acts normal to the surface - if you angle the surface, you change the vector resulting in a reduced downwards vector and adding a sideways one.
Looks like a gimmick to me.
jjn9128
771
Just_a_fan wrote:
17 Aug 2021, 18:21
UlleGulle wrote: Yeah. And It's been done.
Oh fo’sho’ it’s a gimmick.
#aerogandalf
100% a gimmick, it's heavier and gives less cornering grip than a normal stationary wing would. But hey it looks fancy!
UlleGulle
UlleGulle
Just_a_fan wrote:
17 Aug 2021, 18:21
Of course it is.
Slo Poke
Slo Poke
Air rarified diffusers and fifties Dodge Lancer style mechanised rear fin wings is the way to go.
Hoffman900
Hoffman900
203
Like Sprint Cars? They're about the aero equivalent of a sheet of plywood. Most are the way they are due to rules, tradition, and they provide advertisement space.
https://www.motortrend.com/how-to/ctrp- ... odynamics/
Then there are these crazy things:
They're fast (lap speeds of 135mph + average), but mostly backyard engineering / monkey-see-monkey-do.
Xwang
Xwang
29
Hoffman900 wrote:
18 Aug 2021, 16:40
https://worldofoutlaws.com/wp-content/u ... 24x629.jpg
https://speed51.com/wp-content/uploads/ ... amazoo.png
AFAIK indycars used asymmetric aero (front flaps) at least before they became a single constructor serie.
NASCAR cars had a "banana" shaped bodywork so that to generate a centripetal aerodynamic sideforce (with the latest generation they have forbidden that).
