Alfa Romeo C42
Alfa Romeo C42
This is the official Alfa Romeo C42 car thread. The thread has been created to facilitate discussion specifically about the C42 car.
Livery discussion also belongs in the 2022 Alfa Romeo F1 Team thread.
bauc
Re: Alfa Romeo C40 Speculation
f1rules
f1rules
581
Rear and front push rod
jjn9128
770
f1rules wrote:
15 Feb 2022, 13:28
They buy this from Ferrari? So points to Ferrari going the same way?!
#aerogandalf
Formula Wrong
Is it just the camo livery that makes it look that way or does the front of the nose have a steeper "drop" than the rest?
Also, how come it's always Alfa Romeo/Sauber who use a roll bar rather than a roll hoop :D
If you no longer go for the space someone always has to leave, you're no longer a racing driver
Jolle
Jolle
That looks like a very decent car! big undercut and not to bulky sidepods, with hot air venting from the top of the side pods. Lots of space towards the rear.
MercAMGF1Fans
MercAMGF1Fans
Marc.W
26
Side pod intakes look enormous :shock:
F1Krof
94
The nose looks very interesting. Also seems like they've gone with similar sidepod solution to AMR, extreme undercut. The front-wing has unusual shape, not as high as AMR though. Also there is an outboard flap on the floor.
The exhaust though, or is it just an illusion as to how far back pipe exit is?
Wroom wroom
Giando
93
Marc.W wrote:
15 Feb 2022, 13:36
Yes. And the intakes position are also less advanced compared to McL, Haas, AT and AM were it is more or less aligned with the front opening of the cockpit.
Also, roll bar air intakes are very small, reduced even compared to 2021... quite bizarre.
bauc
F1Krof wrote:
15 Feb 2022, 13:38
The exhaust is set like that as per the new regulations, same with others but the different engine cover can mask this.
jjn9128
770
bauc wrote:
15 Feb 2022, 13:39
F1Krof wrote:
15 Feb 2022, 13:38
The tail pipe exit is about 300mm further rearward than last year to stop any aerodynamic blowing effects.
#aerogandalf
F1Krof
94
Wroom wroom
Giando
93
The thin fin on the engine cover is huge!
Also... the venturi channels in the area in front of rear tyres are very bulgy compared to the other cars seen til now, right?
Very wavy front wing mainplane, decent undercut and push rod rear.
