Torsional stiffness of the engine in 2022
Zynerji
109
In Dr. Mario Theissen's paper that BMW published about their F1 engines several years ago, he clearly states his surprise at how much he misunderstood the torsional requirements of the engine at first. He thought the chassis would want an ultra- stiff engine, but he quickly learned that was not the case. I don't recall that he ever stated exactly why the chassis wanted a more compliant block, so I wanted to poll the audience.
Does anyone know why? And is it possible that the return of tunnels and compensating suspension geometry would benefit from a different stiffness?
DiogoBrand
73
Re: Torsional stiffness of the engine in 2022
No idea what's the right answer, but as far as I can tell the first generation of BMW engines in 2000 were quite heavy. So perhaps the benefit was the lower weight, and not the decrease in stiffness that resulted from it.
Hoffman900
Hoffman900
175
Do you have the quote and the context it was presented in? I'm curious what was said and how it was said.
Chassis will resonate, and I believe he might be getting at that. I personally know an example that went into resonance on a shaker rig, and almost flew off. Yikes!
Remember, Formula cars and the like only operate at a couple mm of suspension travel, they're very sensitive to these things.
That said, it could be a weight thing, but you don't want any critical dimmensions inside the engine flexing AT ALL. That's a seized engine or a lot of blowby.
Zynerji
109
Hoffman900 wrote:
23 Feb 2022, 06:09
https://redirect.viglink.com/?format=go ... BMW_F1.pdf
Zynerji
109
I found the pdf, and it wasn't exactly how I was remembering it. He just states that his concerns weren't warranted.
Mods can delete post. Thanks!
Can Google Fmoteurs_BMW_F1.pdf if u want to read for yourself.
Holm86
245
Hoffman900 wrote:
23 Feb 2022, 06:09
I also read at one point that when they tried carbon fiber frames in motorcycles they were way too stiff, and the harmonics caused problems. So they actually preferred the more twisty metal frames, until they discovered how to layer the carbon, to get the rigidity in the right directions
Holm86
245
622
this is what is necessary for the frame to do the suspension's job
if the suspension had to do the job of suspension the resulting vehicle wouldn't look like a motorcycle
Hoffman900
Hoffman900
175
Everything on a motorcycle is different. They started figuring out the too-stiff frame thing in the early 1990s. The chassis + swingarm is a significant part of the suspension at lean. How you even design the engine to work is different, a lot more part throttle work than a car and power has to be tractable.
Zynerji
109
I believe American Sprint cars are also a twist-by-design anomaly...
622
Zynerji wrote:
23 Feb 2022, 23:23
of course ...
torsional stiffness needs to be a v.high multiple of suspension stiffness only to adjust cornering 'balance' by ARB effect
