Intake/outlet ratio in venturi tunnel/diffuser
Tom888
Tom888
I notice that all F1 cars has very high intake of venturi tunnel.
Is this set by regulation or this improve function of venturi tunnel?
If there is no regulation, will you design high intake or very low/close to ground intake if your goal is to maximum downforce?
Is there best ratio for intake/outlet?
high intake,I think at least 30cm
very low "intake" , maybe 5cm, VW IDR,
I think they dont have rules in peaks peek, so does that mean that low intake is best for high downforce?
Stu
Re: Intake/outlet ratio in venturi tunnel/diffuser
Tom888 wrote:
17 Mar 2022, 23:51
https://i.imgur.com/1yNyWmA.jpg
https://media.autoexpress.co.uk/image/p ... wood-1.jpg
The VW has two sets of ground effect.
There is a short front section that outlets behind the front wheels (effectively a front wing), the second one is located under the body and is ‘fed’ by the flow between the splitter and ‘nose’.
The new F1 floors look to have a HUGE inlet, but the inlet strakes tend to divert a large amount of that sideways out of the floor before the ‘throat’. There is an ideal range for the ratio between inlet CSA and throat CSA, somewhere in the region of 1.2-1.4:1. If you try to be too greedy the floor can choke, if you are not greedy enough you give up download. Hence, porpoising….. because they are all seeing how greedy they need to be!!
scheffers
scheffers
Tom888 wrote:
17 Mar 2022, 23:51
All but one 'upright stakes' lead to the outer edge of the floor, at least the cars we have seen underneath so far; to create a sealing vortex on the outside edge of the floor. So they would naturally need some height in the one remaining 'stake' that leads to the tunnel to get in enough air. Correct me if i'm wrong on this.
Tom888
Tom888
Stu wrote:
18 Mar 2022, 09:02
Tom888 wrote:
17 Mar 2022, 23:51
What will happend if you exceed 1.4:1(too big inlet) ?
And what with outlet(diffuser), design maximum without flow separation(stall),can I force diffuser at 25AoA with vortex generators without stall?
Do you maybe have pictures of IDR undertray?
I cant find it...
Stu
Tom888 wrote:
18 Mar 2022, 17:32
Stu wrote:
18 Mar 2022, 09:02
Tom888 wrote:
17 Mar 2022, 23:51
I cant find it...
If you have too big an inlet you risk choking, because all of that air has to go through the throat. As far as I understand it there is no real limitation on the diffuser side (other than minimising turning flow).
I will see if I can find anything on the VW, although it is very similar in ideology to the last LMP1 cars (Porsche 919, Audi R18 & Toyota TS050)
Hoffman900
Hoffman900
175
The complication in all this is the venturi tunnel is only half a duct, with the road surface being the other half and it potentially have leakages. Add in variable ride heights, and this further complicates it.
Also! Where the min pressure center occurs matters for balancing purposes.
Tom888
Tom888
Stu wrote:
18 Mar 2022, 19:39
Tom888 wrote:
18 Mar 2022, 17:32
Stu wrote:
18 Mar 2022, 09:02
I cant find it...
What happend with airflow when is choked? velocity drop instead rise?
Stu
Tom888 wrote:
18 Mar 2022, 20:48
Stu wrote:
18 Mar 2022, 19:39
Tom888 wrote:
18 Mar 2022, 17:32
I cant find it...
Airflow stops (or reduces to a very low level), leading to an increase in pressure and the car ‘pops’ up; relieving the choke.
Tom888
Tom888
Stu wrote:
18 Mar 2022, 22:13
Tom888 wrote:
18 Mar 2022, 20:48
Stu wrote:
18 Mar 2022, 19:39
It is very unintuitive that flow can slow down, if take water hose and decrease outlet diameter with your finger, water is going faster and faster..
Greg Locock
Greg Locock
233
It's called Mach choking and is the formation of shock waves due to incompressible flow. In a wind tunnel you can hear it with a surface mike, it sounds like tearing paper or a raspberry (I never have, it isn't an issue on solar cars).
Image.
https://en.wikipedia.org/wiki/Choked_flow
Hoffman900
Hoffman900
175
What Greg said. Basically for a given pressure differential on either side of the minimum cross sectional area, at choke flow, additional mass cannot be realized.
This is how restrictors work on race engines. As the depression in the cylinder increases with rpm, additional mass cannot enter the cylinder once the restrictor has choked, so the engine “realizes” less atmospheric pressure with increasing rpm until pumping / frictional losses overcome things.
The hard part is you are trying to balance aerodynamic downforce balance, and the fact there are leakages out the sides of the floor , the ground isn’t entirely flat, and the car side is sprung with varying ride heights and not an infinite amount of stiffness.
I am not convinced Merc’s problem is entirely a choked flow issue and not an issue of vortex shedding causing resonance in the chassis.
Tom888
Tom888
Greg Locock wrote:
18 Mar 2022, 23:29
https://en.wikipedia.org/wiki/Choked_fl ... tterns.gif .
You think that airflow reach speed of sound when flow is choked in throat?
I thnik that dont happend in auto racing.
So is flow speed up to 1 Mach or it is slow down in choke condition (in raceing)?
Tom888
Tom888
You mean of this curves strakes at inlet that push air outwards?
Why they push this large amount of air outward instead direct it into tunnels?
If tunnels has skirts to the ground(forbiden by rules), then strakes dont need to go outwards?
Tom888
Tom888
Re: Red Bull RB18
Where is inlet of venturi tunnels here, some picutre that show inlet?
Stu
Re: Red Bull RB18
Tom888 wrote:
19 Mar 2022, 09:45
https://f1tcdn.net/gallery/var/resizes ... /007.jpg
It is not visible in this shot, obscured by the tyre.
