Difusser flow separation and AoA
Tom888
Tom888
If diffuser has to big AoA and flow separate, does pressure under car rise?
Is it possible that we have lower pressure under car when airflow at diffuser is separated compare to when is attached?
What is max AoA for flat floor with curve diffuser configuration?
Re: Difusser flow separation and AoA
You should start with this article, really well explained by a great F1 expert.
https://www.racetechmag.com/2017/08/wil ... diffusers/
#Aerogimli
