[Vehicle/Tire Dynamics] Please help me understand this concept from a racecar-engineering.com article on tire dynamics
Itogliano
I was reading an article on racecar-engineering.com about tire dynamics (full article https://www.racecar-engineering.com/tec ... -dynamics/).
The last paragraph under the section discussing CoF says, "Imagine the contact patch as a matrix of discrete elements. A wider tyre reduces the contact pressure at each element for a given vehicle weight which increases the CoF." Wouldn't the contact patch have to increase in order for the contact pressure to reduce for each element? A wider tire (all else being equal) would change the shape of the contact patch, but the overall area would remain unchanged. Am I looking at this correctly and that statement is incorrect, or is there something I am missing?
The other line of reasoning I come up with, assuming the statement is true, is that a wider contact patch would mean each discrete element in the patch is displaced a less amount (i.e. the tire stays "rounder") which certainly has other benefits, but I don't see how that would lead to an increased CoF.
Thanks in advance
Greg Locock
Greg Locock
239
Re: [Vehicle/Tire Dynamics] Please help me understand this concept from a racecar-engineering.com article on tire dynami
Yes it does smack of 'lies we tell children'. If you have a wide tire running at a given pressure and vertical load, and make it slightly narrower and keep the sidewall height and stiffness the same and make the rim narrower so we don't flex the sidewalls (see how quickly the ifs and buts pile up in real engineering) then a black box regression/physics based model says the lateral dry grip peak drops at that load, partly because the narrower tire has a lower T&RA rated load, as shown in the article, mu drops with load, and indeed load/T&RA load. The contact patch is longer, or at least linear range pneumatic trail increases. The vertical stiffness drops as well.
If you run the two tires at the same proportion of T&RA load then the difference in mu virtually disappears.
579
No doubt the article is assuming the wider tyre is run at a lower pressure.
Greg Locock
Greg Locock
239
Which would also usually get a compound change as well, which directly affects mu.
So as articles go, rather a lot of smoke and mirrors and don't look behind the curtain.
579
Yeah, I long assumed the grip benefit from wider tyres was entirely about the ability to soften the compound courtesy of reduced shear stress but the fact that mu increases with reducing contact pressure is new to me.
johnny comelately
johnny comelately
110
From elsewhere in the forum
http://mccabism.blogspot.com/2019/06/fl ... ffect.html
highly informative and well worth the read imho.
Extract:
'High-performance' racing tyres, of course, are something of a world of their own, and tend to use carbon-black as a filler in high concentrations because it increases hysteresis (i.e., viscous dissipation) and grip. One can find statements in the academic literature such as the following:
"For a typical rubber compound, roughly half of the energy dissipation during cyclic deformation can be ascribed to the agglomerated filler, the rest coming from [rubber polymer] chain ends and internal friction [of polymer network chains]," (Ulmer, Hergenrother and Lawson, 1988, 'Hysteresis Contributions in Carbon Black-filled rubbers containing conventional and tin end-modified polymers').
Given the higher concentration of filler in a racing tyre, one might expect more than half of the energy dissipation, and therefore the frictional grip, to come from the agglomerated filler.
And now comes the interesting bit. Filled rubber compounds suffer from the 'Payne effect'. This is typically defined by the variation in both the storage modulus, and the loss modulus (or tan-delta) of the tyre when it is subjected to a strain-sweep under cyclic loading conditions. (The storage modulus is related to the elasticity or stiffness of the material, and the loss modulus is related to the viscous dissipation).
Greg Locock
Greg Locock
239
Mu increases at low psi (partly) due to cogging. This is the mechanical interlocking/microwelding between the rubber and the road surface. It doesn't need pressure to start happening.So if you plot lateral force vs vertical force the lateral force starts at non zero. If you then divide Fy by Fz this gives a falling characteristic to the mu curve.
johnny comelately
johnny comelately
110
Goodyear unveils 90% sustainable-material demonstration tire, approved for road use
More soybean oil for some race tyres: Today, eight product lines, and some racing tires, include soybean oil.
There have been trials on using bamboo as a source for carbon black.
This 90% sustainable-material demonstration tire includes 17 featured ingredients across 12 different components, including:
Carbon black, which is included in tires for compound reinforcement and to help increase their life, has traditionally been made by burning various types of petroleum products. Goodyear’s 90% sustainable-material demonstration tire features four different types of carbon black that are produced from methane, carbon dioxide, plant-based oil and end-of-life tire pyrolysis oil feedstocks. These carbon black technologies target reduced carbon emissions, circularity and the use of bio-based carbons, while still delivering on performance.
The use of soybean oil in this demonstration tire helps keep the tire’s rubber compound pliable in changing temperatures. Soybean oil is a bio-based resource that helps to reduce Goodyear’s use of petroleum-based products. While nearly 100% of soy protein is used in food/animal feed applications, a significant surplus of oil is left over and available for use in industrial applications.
Silica is an ingredient often used in tires to help improve grip and reduce fuel consumption. This demonstration tire includes a high-quality silica produced from rice husk waste residue (RHA silica), a byproduct of rice processing that is often discarded and put into landfills.
Polyester is recycled from post-consumer bottles by reverting the polyester into base chemicals and reforming them into technical grade polyester used in tire cords.
Resins are used to help improve and enhance tire traction performance. In this demonstration tire, traditional petroleum-based resins are replaced with bio-renewable pine tree resins.
Bead wire and steel cords provide reinforcement in the structure of a radial tire. This demonstration tire uses bead wire and steel cord from steel with high-recycled content, which is produced using the electric arc furnace (EAF) process. The utilization of the EAF process allows for steel to be produced with reduced energy use and higher recycled content. The EAF process has the potential for lower greenhouse gas emissions in comparison with steel produced using a blast furnace.
ISCC-certified mass balance polymers from bio- and bio-circular feedstock are also included in this tire.
https://www.greencarcongress.com/2023/0 ... dyear.html
06 January 2023
671
johnny comelately wrote:
10 Jan 2023, 12:40
... electric arc furnace (EAF) process...
has the potential for lower greenhouse gas emissions in comparison with steel produced using a blast furnace ...
iron is what is produced by using a blast furnace
steel is what is produced (from iron) by using a Bessemer converter
scrap steel can be (and now often is) included with the iron melt being converted
johnny comelately
johnny comelately
110
Tommy Cookers wrote:
10 Jan 2023, 14:27
10 Jan 2023, 12:40
You must be bored Tommy :wink:
