Are panel methodes still used in F1?
Xwang
Xwang
29
Hi,
I'm just wondering if with CFD limited by the rules, some teams could use some less computationally expensive panel methods to do some CFD computation.
n_anirudh
n_anirudh
Re: Are panel methodes still used in F1?
If I am not mistaken, they are mostly for inviscid flows?
While the Re may be of the order of 10^6, the modelling of viscous dissipation is still crucial for the vortices and their location. They may use it as first step.
Alternately, there are options to a do FMG in Fluent, where the mesh size is progressively decreased to obtain a converged inviscid solution and then interpolated to denser meshes to obtain a "starting solution". So as a first guess, these methods serve well.
