Current Formula 1 car sidepod area sizes more larger than pre-2022 cars in fact
theriusDR3
theriusDR3
As you seen the top roll hoop driver onboard view on television, the sidepod area sizes on current Formula 1 car are more larger and the sizes are nearly as large as Dallara IR-05 (2007-2011) IndyCar Series car sidepods
Here’s the look of the current generation of Formula 1 and pre-DW12 IndyCar cars sidepod areas:
The McLaren MCL60 Formula 1 current generation car with larger sidepod areas
The Dallara IR-05 IndyCar Series pre-DW12 generation car with larger sidepod areas
And here’s the pre-2022 Formula 1 car sidepod areas:
The McLaren MCL35M Formula 1 pre-2022 generation car with large to compact sidepod areas
Pre-2022 Formula 1 cars sidepod areas were compact and not as large as current one. Your thoughts?
hollus
Re: Current Formula 1 car sidepod area sizes more larger than pre-2022 cars in fact
The insides are not so large, they sidepod volume is often bumped up for aero reasons, often in a grotesque manner due to the R50 rule. See "zero pods" for the real internals size.
Rivals, not enemies.
