2024 Pre-Season Testing - Bahrain International Circuit, Feb 21 - 23
mendis
mendis
19
LAST YEAR'S RACE SIMULATIONS
MORE INFORMATION
Mod edit: I am copying here the now “traditional” timing sheet created daily by Oehrly:
Oehrly wrote:
21 Feb 2024, 20:06
Hi everybody, it's time for timing data.
Due to popular request, here is the link to the apparently "traditional" Google Sheet with all timing data for the whole day.
(Not sure if anybody else makes these as well by now)
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Please do a bit of a sanity check when using the data. I'm a bit short on time and just quickly tried to bend my upload script into submission, persuaded google to use the correct data types and hope everything is good now.
Day 2 and Day 3 will be added to the currently empty worksheets.
The sheets for 2023 and 2022 are linked in the document as well, if you want to compare.
It should be possible to properly filter and sort all columns by drivers, lap times and so on.
And if you want, you might of course add the link to the opening post so it doesn't get lost as easily.
sn809
sn809
Re: 2024 Pre-Season Testing - Bahrain International Circuit, Feb 21 - 23
Thanks for consolidating the information. Will be an interesting testing as it always is :)
CouncilorIrissa
CouncilorIrissa
The annual pre-season coping thread is here!
Alonso's last years sim was really bewildering to watch with lap times going down due to decrease in fuel faster than they going up due to degradation.
Sawtooth-spike
Do we know who is running on which days yet?
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
Sawtooth-spike wrote:
15 Feb 2024, 13:06
mendis
mendis
19
With Pirelli NOT having made any announcements regarding changing of compound construction, we can believe the compounds are going to be the exact same as last year. So, the lap time comparison would not have that as a variable like it was between 22 and 23.
If temperatures remain similar to last year, which it most likely will, then that's not going to be a contributing factor either.
That leaves us with the tarmac. With ageing, the tarmac would be slightly more abrasive and that surely is going to be a contributing factor on the tyre deg.
Juzh
161
Should mods move this thread in the main general chat? I nearly missed it.
RedNEO
30
15 Feb 2024, 13:06
1.5 days per driver is so ridiculous it almost doesn’t matter lol
Xyz22
Xyz22
84
Only 3 days of testing is so stupid.
RedNEO
30
Especially when they are stuck there for 2 weeks anyway
the EDGE
the EDGE
67
RedNEO wrote:
16 Feb 2024, 11:42
15 Feb 2024, 13:06
Why exactly is it ridiculous?
I’d much rather see more racing, which is what we’re getting. It’s the same for all teams, so it’s fair. Teams will just have to make sure they’re properly prepared & react on the go.
Worst case scenario… some good teams will make mistakes and teams lower down the grid will take advantage. What’s the problem with that?
RedNEO
30
the EDGE wrote:
16 Feb 2024, 12:25
RedNEO wrote:
16 Feb 2024, 11:42
15 Feb 2024, 13:06
It’s ridiculous because if it really was about saving money or being greener they would just have less races. When you have a calendar of 24 races you will have a hard time convincing anybody with a straight look on your face that you’ve saved boat loads of money by only driving for 3 days at the same place instead of 6 or having 2 cars for those 3 days.
the EDGE
the EDGE
67
RedNEO wrote:
16 Feb 2024, 12:37
the EDGE wrote:
16 Feb 2024, 12:25
RedNEO wrote:
16 Feb 2024, 11:42
I don’t know anything about being greener, but it certainly saves money. Testing for 6 days or having 2 cars for 3 days would require twice as many wearable parts… engines, gear boxes, brakes, etc.
Testing brings in zero revenue, racing does
So drivers may be a little rusty at the start of the season. They’ll all be in the same boat, but as I said, I’d rather have more racing than more testing, which is what we now get
Testing is quite frankly boring, I will of course follow, but I certainly won’t be watching
RedNEO
30
the EDGE wrote:
16 Feb 2024, 12:57
RedNEO wrote:
16 Feb 2024, 12:37
the EDGE wrote:
16 Feb 2024, 12:25
They literally race there the week after so they would have to do everything you are suggesting a couple of days later so they save nothing it’s ridiculous.
the EDGE
the EDGE
67
RedNEO wrote:
16 Feb 2024, 13:08
the EDGE wrote:
16 Feb 2024, 12:57
RedNEO wrote:
16 Feb 2024, 12:37
Well no… they are paid to race which pays for the wearable parts. They are not paid to test
