Williams Chassis FW26 PPS #1 - what is PPS?
stevegek
stevegek
Hi! Some one I know is wondering what PPS means. It's written on the chassis plate in an older Williams F1 car. Says Chasis Nr.: FW26 PPS #1
He got some suggestions ranging from Pre-Preg Composite Sandwich, Penske Performance South, Parked Position Sensor and some others...
Anyone know this for sure?
Thanks!
Meep - Meep.
elija6266
elija6266
Re: Williams Chassis FW26 PPS #1 - what is PPS?
Hi there!
PPS in the context of an older Williams F1 car likely stands for 'Pre-Preg Composite Sandwich.
See Pre-preg refers to a type of composite material used in the construction of race car chassis. It involves pre-impregnating fibers with a resin before laying them into a mold. This method results in lightweight and high-strength components, which are crucial for performance in Formula 1 cars.
So, it's quite likely that PPS #1 on the chassis plate denotes the particular construction method or material used in that specific car.
Hope this helps clarify things.
