DRS isn't the only cause of blow by passing
TeamKoolGreen
TeamKoolGreen
-2
DRS keeps getting all the blame for "overfakes" as some people call them. I agree that a lot of passing looks too easy for the faster car.
But the hybrid system is just as much to blame for this as the DRS, if not more. The slightly faster car just follows behind to regenerate electric power. And it can regen more than the slower car. Then when accumulates a power advantage , it just deploys that power and blows by the car in front. And the slower car is depleting power to stay ahead. And this is why cars blow past each other. But everyone sees that DRS flap open and blames that.
I think this is also a huge contributor to the domination we seen in the Mercedes era and now.
All the available electric power should be the same for each car. And the power could be stored for a set push to pass deployment that is the same for everyone. This way , Max wouldn't have any more electric power than anyone else. Then we would see closer racing and harder passes. And DRS would just be there to even out the dirty air.
Some will argue that this is spec. But it isn't. If someone has a better ICE, they can still profit from that.
And this is set to get worse in 2026. 2026 might be worse domination than we've ever seen. Then what ?
This could also be why Moto GP doesn't have nearly the same issues of bad racing. Despite being a prototype series.
Seanspeed
Seanspeed
Re: DRS isn't the only cause of blow by passing
It's mainly the DRS. Take away that and you dont get the same level of 'blowby' passing at all. Saving an engine boost for overtaking opportunities is nothing new in F1, really. And the lead car will absolutely be saving their power for defense in the obvious places, as well. So it balances out. There's no huge advantage to being a following car in this case. A slight one maybe, but nothing game changing.
I mean, we can literally just watch an onboard and see how much faster a car goes once they use DRS. It's very significant.
TeamKoolGreen
TeamKoolGreen
-2
Seanspeed wrote:
30 Apr 2024, 16:37
No it doesn't balance out at all. The faster car can harvest more energy than the slower car while it is following. Because it is using less energy to go the same speed. It tops the battery and then blows past. It is shown in the data.
Tell me how a non hybrid F1 car can build up a burst of horsepower while following.
It has only been this way since hybrid
Seanspeed
Seanspeed
TeamKoolGreen wrote:
30 Apr 2024, 18:36
Again, this difference will be slight and not make any kind of huge impact on the effect of 'driveby' passing. If a driver is fast enough that they can gain any kind of significant harvesting advantage without loss of pace, they were gonna be able to pass easily no matter what.
'Overtaking modes' have been in F1 before hybrids, too. It's just a temporary cranking of the engine to peak/qualifying levels of horsepower. Something that is not sustainable, but is generally fine in short bursts.
Hoffman900
Hoffman900
173
Seanspeed wrote:
30 Apr 2024, 20:51
30 Apr 2024, 18:36
This. And to a lesser extent, it’s even easy to do on a vintage carbureted engine, you just run two ignition boxes and have a switch.
1980s F1 turbo cars had boost knobs on their steering wheels that the drivers could play with.
Kart drivers are always fiddling with the jetting and can do, to a lesser extent, some fiddling.
TeamKoolGreen
TeamKoolGreen
-2
Seanspeed wrote:
30 Apr 2024, 20:51
30 Apr 2024, 18:36
The faster car is simply saving energy because it is following a slower car. Slowing down earlier than it has to because it is being held up. It's physics
Jetting and all that stuff was done for minuscule gains. Not the same thing as discharging horsepower that you are storing up.
Seanspeed
Seanspeed
01 May 2024, 18:00
Both cars will be recovering energy throughout the lap. The lead car will be trying to conserve more in areas where passing isn't possible, and then will use all they can in the obvious overtaking spots. The trailing car will be doing similar, and while they might be able to recover a bit more due to simply being faster, it's not gonna be some huge difference. And like I said, if the car is so much faster than it can actually harvest a lot more without losing any pace, then it was always going to be able to pass easy no matter what.
The effect of this overall will be negligible compared to something like DRS or having a large tire advantage or something.
30 Apr 2024, 16:31
Don't agree with your logic there.
Brake regeneration and MGUH regeneration is much stronger at low speeds or decelerating when the engine is producing more power than it needs to put to the wheels. This is the perfect time, with areas of the track where the opponent finds it hard to pass, to regenerate batteries!
The battery power is not enough of a differential to pass when the other guy in front is using battery power to defend! So yeah DRS is the main reason. Add to that wind direction.
