Mercedes-AMG F1 W10 EQ Power+
TimmTurbo
TimmTurbo
Re: Mercedes-AMG F1 W10 EQ Power+
Lots of winglets underneath the nose. Almost reaching to the barge board front end
Via @hlawiczka
astracrazy
astracrazy
31
It would be good to know the actual surface area of the sidepod openings, because I don't actually think they are much smaller. I think its a bit of an illusion because they are narrow and tall compared to short and wide.
FMP
FMP
At these pictures you can easily see what James Allison was talking about. They have reworked the rear suspension quite a lot. I'm not techincally sound enough to explain it but the lower part of the upper arms is now attaching much further inwards from the tyre. So heavily changed angles and forces for the rear wheels in 2019. Wonder if this solves the rear tyre degradation weakness Mercedes had?
[url]https://twitter.com/AlbertFabrega/statu ... 9090475008
Via @hlawiczka
Sierra117
Hey, they finally used the suggestion I gave them for keeping the Petronas text black with white stroke! =D> :lol:
Sounds lovely, looks lovely, just a week to go now!
NIKI LAUDANZ SolidarityCubolligraphy | Instagram | Facebook
#Aerogorn & #Flowramir
carisi2k
Lewis should be happy with this car. Here is another championship capable car. Look at the nose and front suspension.
NtsParadize
NtsParadize
The high rear wing looks ugly and weird
F1Krof
95
carisi2k wrote:
13 Feb 2019, 13:16
We don't know that yet. Everything's open at this point.
The car looks simply interesting, as do all Mercedes' cars.
Wroom wroom
dren
227
They retained the upper front suspension mounts while STR reverted back to a lower in wheel hub mount. Very tidy sidepods. Looks to be the most developed of the cars out of the box that we've seen so far which should be expected. I'm sure Ferrari will be the same.
Honda!
Benii6
Benii6
carisi2k wrote:
13 Feb 2019, 13:16
What about the fat air intake and a fat rear wing?
F1T
Administrative bot
Mercedes W10 Launch Analysis
Mercedes unveiled their car on the track of Silverstone a hour before noon. The reigning champion is the first to show a 2019 car in real life, with a shakedown planned under the guise of a filming day. F1technical did a first analysis/impression of the car
NtsParadize
NtsParadize
The rear wing attachments look like LMP1
dren
227
James Allison wrote: "Every item is pushed tighter, made more slender - each change permitting us to improve the aerodynamic performance beyond what would have been possible had we accepted the physical limitations of the 2018 design."
You can definitely see it in the chassis - nose junction and in the sidepod width.
Honda!
