Mercedes W15
matteosc
matteosc
30
Re: Mercedes W15
Different engine cover could be for different cooling requirements (but it could be for aerodynamic purposes as well)
matteosc
matteosc
30
Re: Mercedes W15
Nice pictures! It seems like that are following Ferrari/Red Bull for diffuser shape (big smooth keel in the middle). Plus single element beam wing… any thoughts about that?
Brahmal
Brahmal
Re: Mercedes W15
Also, notice the upper corners of the diffuser have substantially more sculpting and volume taken out right behind the exit. I'm assuming the exterior and interior shaping correspond.
Re: Mercedes W15
Re: Mercedes W15
zioture wrote:
18 Oct 2024, 23:35
Inside the diffuser is maybe 15 mm taller.
Luscion
Luscion
Re: Mercedes W15
Re: Mercedes W15
Looking at edge wing, this is the latest Mercedes floor. That front "depression" near the boat section is significantly high. Photo by motorsport
AeroGimli.x
Andi76
Andi76
431
Re: Mercedes W15
Farnborough
Farnborough
103
Re: Mercedes W15
From observation and words spoken by the team:-
LH spoke of "left front bouncing" when he crashed at COTA.
TW has now said about problem "three wheeling" after Mexico.
GR slo-mo in FP crash, I belive showed that front wheel bouncing showing the three wheeling characteristic, albeit initiated (or so it seemed) by running at very high load over the curb.
It looks as though the plank is being used in mitigation of rear end bouncing, leaving alot of debris from floor coming out the back sometimes.
The rear suspension APPEARS to have more travel than they've got clearance under the car, such that the suspension is not forced into a high energy stop which is subsequently distributed into the rear tire carcass.
To lift the front wheel generally on a F1 car (excepting bouncing over a chicane) then you'd conventionally need to increase rear wheel "travel" or as seen in a rear puncture when that lifts one front diagonally opposed to that deflation.
Here though, it appears they are very deep into wheel travel on rear to create that effect.
Its quite different to how the others are operating, with one front lifted and rear partly sitting on it's plank, not surprising it acts with such abrupt attenuation of peak grip. George didn't even have time to get much in the way of opposed lock on it came at him so fast in that Mexico event.
Lasssept
Re: Mercedes W15
Clubman1d
Clubman1d
Re: Mercedes W15
Re: Mercedes W15
Clubman1d wrote:
31 Oct 2024, 18:56
Different air intake shape?
This is the updated sidepod/intake from COTA
Re: Mercedes W15
Isn't exactly a hidden shark mouth, but I guess the intent is the same. It's all to get cleaner flow influence near the floor edge wings and better outwash.
Vappy
Vappy
Re: Mercedes W15
Car reportedly bouncing. Is it just this car suffering?
F1Krof
94
Re: Mercedes W15
They have no clue.
Wroom wroom
