Williams FW47
trinidefender
trinidefender
318
Re: Williams FW47
tomazy wrote:
14 Feb 2025, 18:32
So, after looking throgh a lot of pictures and reading everything I could find, The car looks to be an agressive evolution of FW46.
It has an entirely new nose cone and front wing, similar to the McLaren and RB cars.
Front brake ducts are smaller, even tho the inlets are about the same, but the outlets are smaller and more complex (I cant find the picture where I saw that).
Front suspension is still pullrod, but it has new geometry, more agresive antidive. there is no new halo aero.
Engine cover is lower (shorter behind the airbox) and narrover (it is streight at the Gulf logo, and not buldged out).
I didn't see any good pictures of the watterslides, but I asume that they are there, the air to them should be less disturbed, becouse the line around the headrest is streighter than last year.
Udercut is huge, and it even turns upwards, the line where the floor mits the chassis is smoother and less disruptive. Floor edger look to be more comlex.
It has 2025 Mercedes rear end with push rod suspension.
The high downforce rear wing I think is the same as last year, but the low DF one is new, with detached edges of the upper plane at the endplate.
The color looks good, I hope that the official racing livery is even better.
https://www.racefans.net/wp-content/upl ... _HiRes.jpg
Front suspension is pushrod
tomazy
tomazy
220
Re: Williams FW47
trinidefender wrote:
16 Feb 2025, 19:42
tomazy wrote:
14 Feb 2025, 18:32
Yes, you are right, it was a typo sorry.
tomazy
tomazy
220
Re: Williams FW47
16 Feb 2025, 19:42
tomazy
tomazy
220
Re: Williams FW47
Picture of the sidepod intake and the floor edge, taken from video in the link below.
WATCH: JV Talks Drivers, Atlassian and Planning for the Future
Re: Williams FW47
New medium load BW for this season. It was there during launch, but obscured on purpose - along with entire rear end of course
bananapeel23
Re: Williams FW47
Emag wrote:
14 Feb 2025, 15:59
Looks much more "normal" on the images shared by Vanja a couple of replies earlier. The shadows play some trickery on the closeups.
I just spotted the flow-viz on the Mercedes. The big SIS bumps are absolutely being used intentionally as an outwashing element to try and clear the air before it flows over the floor edge wing. There was absolutely zero flow-viz behind the edge wing and there were some very clear lines that indicated that the SIS bump was outwashing pretty heavily.
Obviously that doesn't conclusively prove that it's being used in the same way on the Williams, but I'd argue it very much indicates a similar intention. Obviously it isn't necessarily the primary purpose of the SIS placement, it could have just as much to do with the floor inlet, but I do still believe it's intentionally placed very high up at least in part to promote outwashing.
Mr Brooksy
Re: Williams FW47
Interesting eye ball analysis of the past two days running from the Race. I'd really like to see some race sims and the comparisons so we have a better guess on where Williams stands.
Really want Williams to be closing in on the top 4!
https://www.the-race.com/formula-1/edd- ... acesetter/
WilliamsF1 fan since 1989
Brahmal
Brahmal
Re: Williams FW47
SiLo
139
Re: Williams FW47
Quite the interesting development this! I wonder if they have found that accelerating flow in that region helps pull more flow through under the wing?
Waiting for the resident aero experts to tell me how dumb I am.
Felipe Baby!
F1NAC
172
Re: Williams FW47
Wasn't the purpose of these curved wings in this era cars supposed to eliminate possibility of creating edge vortexes that makes air dirtier?
tomazy
tomazy
220
Re: Williams FW47
New front wing in Japan!!! The new one is the one in rhe back.
1: Blue, new kink in the upper two elements of the wing.
2: Red, a wertical fance where earlier there were only swan nack connectors connecting the wing elements (you can comare it to the wing in front)
3: Yellow, a more extreme outwash of the ends ot the wing elements
4: Green, a cutout of the endplate.
This are the changes I found with the limited images, there might me more.
https://x.com/n_mode_log/status/1907756421032317356
Moctecus
153
Re: Williams FW47
Power unit installation
FW47:
via PlanetF1
FW46:
via PlanetF1
Luscion
Luscion
109
Re: Williams FW47
Upgrades for Japanese GP
