Via @AlbertFabrega
Guessing bottom spec is Monaco, as it is similar to what they ran in Melbourne. The specification with 3 hanging strakes has been used in the past few races.Morteza wrote: ↑22 May 2019, 18:13Diferent endplate configurations
https://pbs.twimg.com/media/D7LwdmFWkAIdgdl.jpg
Via @AlbertFabrega
The normal push rod mounts against the upright via a rose joint. This allows for the rotation of the upright with lock.
okay but wasn't this illegal in, i believe 2016? or at least doubtfullJust_a_fan wrote: ↑23 May 2019, 00:07The normal push rod mounts against the upright via a rose joint. This allows for the rotation of the upright with lock.
The extended pick up of the Mercedes will result in greater radial movement of the pick up point - follows the surface of s sphere rather than being mounted on/ close to the axis of rotation. Result is a different connection.
thanks alotMaplesoup wrote: ↑23 May 2019, 20:35A video of it in action can be seen here
https://www.instagram.com/p/Bx0J12yIhcz ... jwck73o4lp
'Old photo' (what's called old...
Mercedes' front Suspension Analysis
Slow turns were the weakest aspect in the Mercedes W9 and specially the W8, their long wheelbase (longest of the grid) was a problem in slow tracks like Monaco, as their pressure center moves backwards a lot as speed decreases, generating understeer due to the loss of front downforce.
Before the start of the 2018 season, FIA introduced a new technical regulation (after Ferrari's suggestion) that limited the hight variation of the floor (front) with the variation of the direction angle. Therefore since 2018, a suspension system called "Pushrod on Upright" is legal.
Ferrari tested this system later on during the 2018 season, but isn't using it this year. However, Mercedes noticed that this system was perfect to solve their slow turn problems in 2019.
In the video, you can see how the W10 moves down significantly when the turning angle is at its maximum in the Monaco hairpin.
