basti313 wrote: ↑07 Apr 2025, 14:47
Ben1980 wrote: ↑07 Apr 2025, 14:08
I'm not sure going long would work. The hard tyres were faster and the lack of degradation made no offset options. The only real option was to pit Lando instead of Oscar.
The point would simply have been to pressurize RedBull to an earlier stop. We have seen it on Russel, he had a very good outlap, so pushing was possible.
I know they tried the dummy early stop, but Horner knew that was no chance due to traffic.
I do not see that. Piastri had a nice gap before Alonso to pit into and the pace was there to use it. We saw that he lost 2sec to Russel who pitted one lap earlier. That would have put RedBull into the position of a need to pit.
I also do not see why the overcut should not work. We saw some 33 low and a 32 high by Norris on the inlap. After the stop Verstappen did 32 mids at best. So with clean air, I can not see a time loss above 2-3 sec by staying our for another 6 or 7 laps.
6 or 7 laps brings us to a tire delta of around 0.3sec per lap. With a remaining 20laps to go for me this is a no brainer to go with an overcut and not to follow Max into the pits.
An "opposite Verstappen" call would in any case be the right thing to so here. It is just blocked by them managing the intra team battle.
Sending Piastri to pit first was a bad call. The best way would have been to send Norris first to get a true undercut on Verstappen, and then go long with Piastri to attack Verstappen with two different strategies. Good undercut means Lando wins, any lucky SC gives victory to Piastri, good tire offset gives victory to Piastri, etc. Many more options than what happened. But after the made the mistake of going first with Piastri, going opposite VER was a sensible idea. I'm quite surprised they didn't do that.
Btw Antonelli had a tire offset and he was faster about 3 tenths per lap than Norris on the hards. It is likely that Norris with tire offset would be 5-6 tenths faster than Oscar and Max. Would it have worked, who knows but it was worth a try. Same would apply to Oscar.
Farnborough wrote: ↑07 Apr 2025, 15:40
Theres much information proffered here in support of what they did for that outcome. Thats, ultimately, just reading what happened though.
It's the task of McL team and strategic arsenal to specifically "short circuit " that status quo in their plans, those to match the output of their technical team in accomplishments.
It was ordinary thinking giving ordinary output in reality.
They state the advantage of two against one and fail to action that.
They need to think more Ross Brawn and that ilk in their outlook.
Fully agreed. We are still waiting for that Red Bull strategy guy to join the team, if I remember correctly he will join in 2026.
Btw I am fully opposed of the view that nothing could have changed the outcome that some other posters shared. I don't agree with that. Even a simple "Piastri pits after Norris" would mean Norris would get undercut on Verstappen and if their stops were the same as in reality, Norris is ahead of Verstappen. But even if we ignore that, they SHOULD have done something different as the way they went about things meant there was no chance of strategy overtake.
Thinking nothing could have changed is a coping mechanism that the team (and fans) should not use.
One of my theories is that they expected to have much better tires than Max at the end of the race and thus, it didn't make sense to do a riskier strategy to overtake him. Why do that if he will come to you at the end of the race. This obviously didn't happen and if that was their thinking, while I can understand the logic, it is based on a flawed assumption.
