Pany
Pany
Re: Renault V6 Power Unit
Is renault engine going soon to be the last engine in the f1 grid performance wise?
roon
roon
412
ripper wrote:
07 Apr 2018, 11:57
https://cdn-6.motorsport.com/images/amp ... 036678.jpg
https://it.motorsport.com/f1/news/red-b ... t-1022741/
Sorry I am not sure about "cassoncino di aspirazione" translation, it could be inlet air case (or maybe air intake system)
Some sort of rotary feature inline with the intake runners. (yellow circles) Throttle plates? Some say these aren't used in the current formula.
Also, I found the source of Renault's compressor inefficiency (green arrows).
Big Tea
99
roon wrote:
07 Apr 2018, 22:18
ripper wrote:
07 Apr 2018, 11:57
https://i.imgur.com/5udyUzc.jpg
Would they not be mount holes? or are you just being ironic?
Big Tea
99
Big Tea wrote:
07 Apr 2018, 22:38
roon wrote:
07 Apr 2018, 22:18
ripper wrote:
07 Apr 2018, 11:57
Edit.
Sorry, I am slow today
carisi2k
27
are those holes or stickers?
232
Those holes are for tools to pass through probably.
They are also present on the mercedes air box. Maybe for vilm adjustment.
roon wrote:
07 Apr 2018, 22:18
ripper wrote:
07 Apr 2018, 11:57
I reckon the throttle plates are metal and bolted onto the head similar to the V8 engines.
zac510
zac510
22
It's a joke, that the turbo'd air is escaping out the holes!
It's a pivot, either for the throttle bodies or for the VLIM system - you can see the rose-jointed control linkages further back.
Hydraulic VLIM?
trinidefender
trinidefender
318
godlameroso wrote:
08 Apr 2018, 21:39
Hydraulic VLIM?
Doubt it, would guess electro-mechanical actuators.
ctdrftna
ctdrftna
Lower holes are the shafts for the throttle blades, and the upper holes are just access for the flange bolts in that area. they are not open to the inside of the plenum.
trinidefender wrote:
08 Apr 2018, 21:57
godlameroso wrote:
08 Apr 2018, 21:39
Hydraulic VLIM?
Electrically controlled, hydraulic operated, much faster than only solenoid driven. The weight penalty is almost negligible and the benefits of faster VLIM control I think would be worth it. But eh, not my pumpy lump.
Surprised no one talks about the shape of the ports.
648
what's solenoidal action got to do with it ?
I thought eg the (NA) throttle actuation was based on electric motor action
rotational or linear
proportional and precise
trinidefender
trinidefender
318
godlameroso wrote:
08 Apr 2018, 22:05
08 Apr 2018, 21:57
godlameroso wrote:
08 Apr 2018, 21:39
Hydraulic VLIM?
Modern electric actuators can have quicker reaction times and be more precise than hydraulic ones.
Aircraft are moving away from hydraulic actuation to electric for this very reason. (As well as reliability).
The cons are more expensive and still generally not providing as a force, neither of which is a factor in this application in F1.
Also as TC said, they don't need to be solenoidal action isn't the only way.
