CAn anyone help me with this ?
You mean this ? "A diffuser, in an automotive context, is a shaped section of the car underbody which improves the car's aerodynamic properties by enhancing the transition between the high-velocity airflow underneath the car and the much slower freestream airflow of the ambient atmosphere. It works by providing a space for the underbody airflow to decelerate and expand (in area, density remains constant at the speeds that cars travel) so that it does not cause excessive flow separation and drag, by providing a degree of "wake infill" or more accurately, pressure recovery. The diffuser itself accelerates the flow in front of it, which helps generate downforce."soumyakd wrote:I have been digging into the exact step by step process of how an underbody diffuser works, but every theory leaves a flaw behind which i dont understand clearly nor i can solve it out by myself. So, can anyone help me with a clear cut explanation of how the expanding area of diffusers help in gaining downforce ( I do understand that the increasing area fills up the wake behind the car) ?
And an elegant way of stating it, too. Thanks for the link - I'd missed that thread.hollus wrote:The diffuser is an elegant way of moving this partial vacuum from behind the car, where it causes drag, to below the car, where it creates downforce.
How does mating with the wing bottom create a vaccum ? I understand that the diff does create a vacuum effect which sucks in more air from the underbody. But how ?coaster wrote:I'll take guess that the beginning of the diffuser angles away from the floor at 8 degrees or less, and tries to mate up with lowest rear wing element to pull the air out of the tunnel, creating a vacuum under the floor in front of the diffuser entry, pulling the back of the car down? Maybe? Dunno!
Here's an old article from my blog, explained rather simple, particularly about F1 diffusers.coaster wrote:This is why I'm a tradesman and not a designer, it's very hard to visualise what was described here and probably so more with the necessary algebra to fill the description with facts.
If I was born in ancient Rome, I'd strangle Pythagoras and make visual diagrams standard over friggin algebra!
While you graphics are correct, i'm afraid your blog explanation is not or not correctly worded.Kiril Varbanov wrote:Here's an old article from my blog, explained rather simple, particularly about F1 diffusers.coaster wrote:This is why I'm a tradesman and not a designer, it's very hard to visualise what was described here and probably so more with the necessary algebra to fill the description with facts.
Some visualization of this with Venturi pressure gradients from Symscape:
http://4.bp.blogspot.com/-yBL4Z78fMsE/U ... effect.png
agreed. but How is vacuum produced when the air slows down ? Slowing down suggests low velocity..so higher pressureOgami musashi wrote: Now why does the diffuser accelerates the flows in the undertray? This is because the air is slowed down in S2...but the density stays the same (at the speed a car travels); the word "expand" is misleading, the air is not stretching is actually just slows down...and thus a "vacuum" is created and since nature doesn't like it it will be filled...by air coming from the undertray...in other words the diffuser will pump air from the undertray to fill the whole S2 section and the S1V1=S2V2 principle will be verified, only that V1 will be even greater than if the diffuser wasn't there and S2 will be slower.
and thus downforce.
Hope this helps.
