politburo wrote: ↑19 May 2021, 19:01
I did not discuss horizontal movement, I discussed vertical movement as that is the narrative I came across. You might have missed that yet it was explicitly mentioned as such in the original post. Read it again maybe.
Oh you mean the rotation around the support pillar when looking from the side?
The rotation is essentially the cause of any observable horizontal movement of the
wing relative to the camera, isn't it? It can't just move up/down without it. So there's no seperate "vertical movement" of the
wing.
That's why you got me confused, i did not "misconstrue" anything, i misunderstood - big difference since one is done by mistake and i must admit that i completely missed that you wrote 'vertical' initially and then thought you flipped words because "vertical movement" in this context didn't make much sense to me, my bad, sorry.
From the camera angle we can't deduce by how much the
wing is moving 'backwards', it simply isn't possible - but the answer is still the same though: ANY movement of the
wing that we see relative to the camera is independent from what is happening with the suspension which doesn't mean that bumps and curb riding that get transferred as 'hits' to the chassis and thus the
wing don't make it shake, but that's that. So yea, maybe a harder suspension could lead to bigger "peaks" in the movement but only momentarily.
And as i just wrote, there's no clearly observable movement side to side from the camera's pov apart from some oscillations and wobble.
I can only point you to this:
viewtopic.php?p=971132#p971132
In the images i actually rotated the
rear wings around the marked "possible pivot points" - so that's your vertical movement, i guess?
I'm also surprised that anyone would be talking about any vertical movement in the first place, where'd you come across it?
