RZS10 wrote: ↑22 May 2021, 19:47
So those components aren't even remotely close to the F1 designs and thus can't be compared to F1 parts (at least under the current regulations).
F1 regulations permit thick parts for the sharkfin and
rear wing endplates too, it's the teams who choose to make them thin and flexible, almost as if deliberate.
Dallara shows that, even on a cost-orientated vehicle, it is easily possible to make these parts very rigid when so desired... The rules do say the parts are meant to be immobile with respect to the sprung part of the vehicle, so teams should be designing to that goal for
all bodywork...
The front
wing has two flaps that are connected on the inside,
Five elements in F1 for the front
wing is a maximum. Teams are permitted to have two elements only, if two elements is what is needed for a stiff flap that allows their front
wing to be immobile and rigidly secured for complying to the regulations in best faith.
The tubs, for example, have no issue with being rigid.
So I would put severe load tests on the mirrors, the front
wing & flaps, the
rear wing & flaps, the sharkfin, and the bargeboards (or vortex generators in 2022 rules), to make sure teams are designing their parts extra thick, in good faith for minimal deflection. Hopefully that would put flexible bodywork suspicions, on ALL parts of the car, to bed for good!
How about 50kgf on the mirrors, 100kgf laterally on the sharkfin, 350kgf on each side of the front
wing, and 700kgf on the
rear wing? I think that ought to do it. If it's worth doing, it's worth overdoing!
