DChemTech wrote:Hoffman900 wrote: ↑31 May 2021, 17:43
Exactly. As Scarbs pointed out, this is premeditated, designed flex, not accidental. Anyone claiming anything else is naive. That is a direct infringement of the rules and the FIA should have squashed it a year ago. Redbull (and other teams) knowing this, should have been prepared to have to go to a different
wing at any point of time, this is why the grace period is ridiculous.
Eh, yeah, of course it is, I am not disputing that. As an engineer, you try to hit the limit of what the rules allow. If you impose any additional restrictions on yourself while your competition is not, you are losing ground. No team would do that. What I want to know is what is the dividing line, objectively, by a
wing that flexes too much, and one that doesn't. By what quantitative criterion is the flex of an MB or McL
wing allowed, and that of a Ferrari, RB or AR
wing not.
And I agree with you that the FIA should have squashed it before, if the observed behavior is what they deem illegal. But that is fully a failure of the FIA. You can't blame RB, Alfa, Ferrari, etc. for not abiding to rules that the FIA failed to put up in the first place.
SmallSoldier wrote:
You keep missing the point that if Red Bull has designed or engineered additional deflection in their wing, they are infringing Rule 3.8... The set of tests in Rule 3.9 account for the fact that materials can’t be 100% rigid... But there is a difference between flex been a by product of the materials used and flex been designed into a part... If the latter, the teams will most probably (just like in 2014) be penalized.
But
has this been shown to be the case?. And with that I mean, is there some specific element, like a connecting piece (as was the case in the 2014 FW situation, AFAIK), that is designed to yield beyond the test stress? If that is so, I concur that can be interpreted as a deliberately moving part (as I pointed out before), and that would arguably be a violation. So if this has been indeed shown to be the case, that's that. Is any connection OK provided there is always a (sub-)linear deflection/load relation? Is some none-linearity allowed provided there are no indications that any part has been designed to be excessively flexible at higher loads (and what is excessive, then)? Where is the limit between 'designing for deliberate flex' and 'designing to be on the flex tolerance'? None of that is there! So even if it was clear that some teams were violating a rule (which still seems contestable), it is not clear what those teams should have done to abide that rule, nor is it clear by what standard it is decided that the wings of those other teams are deemed 'not designed to flex'.
I don’t have any information to determine what is happening with the
rear wings and none of us will be the ones ruling for or against in a potential protest... Nevertheless “my opinion” is that the flex in some of these wings have been designed into the parts and in that case it’s a clear infraction of article 3.8... What do I base my opinion that it is indeed the case:
A) A couple of teams have already made public statements in regards to this... Binotto has openly stated that they have been exploiting the way the current tests are done and will bring forward wings that will comply with the new set of tests.
B) Vasseur has also openly stated that they have a
wing design to do this and not only that, but that they have done back to back tests with a
wing that does flex and one that doesn’t flex, suggesting that the flex is a design element of their wings.
C) The FIA statements when the new TD was issued implies that the current amount of flex is considered excessive and therefore they are adding additional tests to curtail this.
D) During this whole saga, none of the teams with a flexible
wing have stated that the current flex is part of the expected flexibility of the
rear wings... Their statements have been only made in reference to “passing the test”.
E) There are teams on the grid that have wings that flex way less than the suspect wings, which shows that it is entirely possible to manufacture
rear wings with a lesser degree of flex.
F) The threatening from Marko/RBR to counter protest if Mercedes acts against their
rear wing in Baku, if they would be comfortable that there is no illegality on their
rear wings and comfortable with their position, they wouldn’t need to make such a threat... Based on their comments, they are concerned about a potential protest.
The above is only an opinion with no data to back it up and we won’t be able to quantify it until the new tests with the markings on the wings and the use of the
rear camera are used to determine the amount of flex... Been said that, the FIA will have a chance to look deep into the wings and find out how the flex is been generated, article 3.8 covers both “design” and “construction”, so the use of clever ways of carbon layup and other means to induce aeroelasticity would be penalized if present.
