Mc Laren MP4/24 aero-mech development in 2009
BreezyRacer
BreezyRacer
Re: Mc Laren MP4/24 aero-mech development in 2009
tahadar wrote:the MP4/24 rear wing slot was quite interesting at singapore. there is plenty of room for innovation in that 75mm-wide legality box :)
I sure would like to see some CFD on one of those slots. I can see it reducing drag a bit I wonder what it does for DF?
probably keeps air attached or something like that.
For the mclaren slot it might make the wing less sensitive, but i think that is irrelevant for the regular slots
tahadar
tahadar
allows you to run at higher angles of attack without seperation. check out the post by newbie on page 292 here: http://forums.autosport.com/index.php?s ... tart=11640
along with this pic: http://premium.f1-live.com/f1/photos-hi ... po_266.jpg
Pedro
Pedro
Singapore updates - experimental front wing and diffuser
McLaren tested new wing with totally new end-plate in Singapore but did not use it in qualification or in race. (They tested this piece already in Valencia and at Spa I guess).
McLaren also used a new symmetrical rear diffuser, replacing the previous asymmetrical design introduced at the Nurburgring.
They had also new floor. McLaren changed Hamilton's monocoque due to KERS cable problem. It was easier to change the monocoque than to repair it. So it was not because of performance reasons or new parts.
You can read more about aero updates here: http://www.f1news.cz/technika/33249-ino ... ni-kridla/
Source: F1news.cz
bar555
bar555
FRONT WING - ITALY
REAR WING - ITALY
The size of the flaps is dramatically reduced but the overall wing’s style remained similar to Spa concept . The main profile was also raised in its central section , the three horizontal slits also remained but the gurney tab was removed . A low downforce spec rear wing is vital for achieving top speed at long Monza’s straights .
NOSE CONE CAMERA WINGLETS - ITALY
The nose cone camera winglets were repositioned higher to the nose cone , just above and frontier the upper suspension wishbone linkage .
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
deus1066
deus1066
They've got some new bargeboards for Suzuka, and they're continueing to use the new diffuser.
deus1066
deus1066
deus1066 wrote:They've got some new bargeboards for Suzuka, and they're continueing to use the new diffuser.
Pedro
Pedro
New deflectors in Suzuka
compared with previous version used in Singapore:
http://f1news.cz/technika/33338-zmeny-n ... -zbrojeni/
Source: F1news.cz
bar555
bar555
EXHAUSTS - ITALY
DIFFUSER - ITALY
FRONT BRAKES - ITALY
REAR BRAKES - ITALY
bar555
bar555
GP SINGAPORE
Undergone changes from Monza
1.Nose cone camera winglets
2.A new front wing was tested
3.Minor changes to the floor
4.Exhaust outlets
5.Revised rear wing
6.Heavily modified diffuser
McLaren changed Hamilton's monocoque due to a KERS cable problem
Ciro Pabón
106
bar555, I just want to say thanks again. The best threads on cars are all yours. I bet half the visitors come because of these threads, beautifully illustrated and straight to the point. I dare to think that if some team wants a truly good spotter, they should consider hiring you.
Ciro
xpensive
xpensive
214
Can someone xplain the loophole in the rules that allows for the return of such deflectors and barge-boards? Scarbs?
bazanaius
bazanaius
AFAIK the boxes within which overlapping surfaces are prohibited are defined relative to car surfaces. teams have got around this by shifting bits of the car (sidepods backwards for example) to creat unregulated space in which they can add dangly bits.
Anyone confirm?
axle
axle
bazanaius wrote:AFAIK the boxes within which overlapping surfaces are prohibited are defined relative to car surfaces. teams have got around this by shifting bits of the car (sidepods backwards for example) to creat unregulated space in which they can add dangly bits.
Anyone confirm?
Yep that's how I understand it too...
- Axle
shifting the sidepods backwards is wrong i believe, the position of these are regulated becauce of driver protection. i believe these parts have to do with vieuws from certain positions and the body work at the sidepods length has to do something with the sidepods width i guess.
