Not an opening, every year the same story
I think that is a shadow, we had similar pictures from other cars last year.
It is really there, inside overlaps the outer panel. Laterally squirts air towards the rear tire.
Haha so meta POSTVenturiation wrote: ↑23 Feb 2023, 18:51the team is here
https://pbs.twimg.com/media/FpqnfFyXwAE ... me=900x900
Could you share?BlueCheetah66 wrote: ↑23 Feb 2023, 19:27I thought it was a shadow at first but I've now seen several photos with it present from different angles so it likely is there
Might have to go back on myselfMV8 wrote: ↑23 Feb 2023, 19:46Could you share?BlueCheetah66 wrote: ↑23 Feb 2023, 19:27I thought it was a shadow at first but I've now seen several photos with it present from different angles so it likely is there
BlueCheetah66 wrote: ↑23 Feb 2023, 19:56Might have to go back on myselfMV8 wrote: ↑23 Feb 2023, 19:46Could you share?BlueCheetah66 wrote: ↑23 Feb 2023, 19:27I thought it was a shadow at first but I've now seen several photos with it present from different angles so it likely is there
https://pbs.twimg.com/media/FpqPfnZXsAA ... name=large
From this picture the 'slot' has a different shape to the previous image. It could still be a slot that could look different based on the angle, but I would find it more likely to be a shadow due to that
It’s real, it’s not a shadow.MV8 wrote: ↑23 Feb 2023, 20:00BlueCheetah66 wrote: ↑23 Feb 2023, 19:56Might have to go back on myself
Seems like a shadow, in the picture the slot looks like is going upwards in the blue mark. Does not make much sense for me.
https://i.imgur.com/05hHhnT.png
Pretty clear to see there's no slot on the left hand side of the diffuser. This is an absolute red herringBlueCheetah66 wrote: ↑23 Feb 2023, 19:56Might have to go back on myselfMV8 wrote: ↑23 Feb 2023, 19:46Could you share?BlueCheetah66 wrote: ↑23 Feb 2023, 19:27I thought it was a shadow at first but I've now seen several photos with it present from different angles so it likely is there
https://pbs.twimg.com/media/FprDfJJWAAE ... me=900x900yinlad wrote: ↑23 Feb 2023, 20:31Pretty clear to see there's no slot on the left hand side of the diffuser. This is an absolute red herringBlueCheetah66 wrote: ↑23 Feb 2023, 19:56Might have to go back on myself
There clearly is one on the left side.yinlad wrote: ↑23 Feb 2023, 20:31Pretty clear to see there's no slot on the left hand side of the diffuser. This is an absolute red herringBlueCheetah66 wrote: ↑23 Feb 2023, 19:56Might have to go back on myself
