Ferrari SF-24
Re: Ferrari SF-24
FDD wrote:
06 Aug 2024, 15:22
It looks to me like they put some kind of patch, not a completely new floor.
Most likely this section was cut out from Barcelona-spec floors and replaced with a part of different geometry
Re: Ferrari SF-24
SF24 in Zandvoort, Barcelona specification for all 3 wings and no apparent changes to the floor edge and rear corner, photos from Motorsport.com
murphy
murphy
Re: Ferrari SF-24
K1Plus wrote:
28 Jul 2024, 22:25
Could a lack of flex on the front wing cause the understeer?
The Ferrari has the worst front end of all top four teams, you can see the understeer in every corner, more likely to do with the suspension.
codetower
Re: Ferrari SF-24
This thread is for technical discussions about the SF-24, not team talk, speculations, etc.
<mod addition: this post was in response to a series of posts that could not be more off topic in a car thread; those have been removed. Leaving this one here as a reminder: no winning and losing in the car threads, use race threads and team threads for that, thanks.>
Xyz22
Xyz22
123
Re: Ferrari SF-24
yooogurt
40
Re: Ferrari SF-24
a very low-load front wing for the Monza Grand Prix.
@GiulyDuchessa
FORZA FERRARI!
Re: Ferrari SF-24
Very well thought out, every details seems a small improvement over 22/23 spec wing. Seems like the wing and flap profiles are very similar in angle, shape and size, but the leading edge has a different curve along the span definitely. The transition towards the tip is much more subtle, while the endplate extension itself is a lot flatter and the curve is much smaller now - effectively increasing the span before tip losses start ocuring.
Obviously, there's a single pylon and connected to the DRS mechanism. Since these two photos are from different angles, no way to truly compare their size and angles. However, we do see a flat flap extension, while the very tip of the flap is cut off to absolutely maximise the efficiency by reducing frontal area where the losses are biggest.
Re: Ferrari SF-24
High quality photos by formu1a.uno team. Rear wing is particularly good looking, clear step above 22/23 wing design in terms of tip flow conditioning and details.
Re: Ferrari SF-24
Re: Ferrari SF-24
That's almost a perfect size comparison, new wing is at 98.5% span of the new one. After correcting it, it turns out the new wing is even smaller in height, by about 15-20mm. I was 100% sure they will go bigger, but there we have it
Luscion
Luscion
101
Re: Ferrari SF-24
Re: Ferrari SF-24
Second photo is from motorsport, third is Fabrega. No more g flap on the beam wing like last 2 years
Emag
Emag
97
Re: Ferrari SF-24
Vanja #66 wrote:
29 Aug 2024, 13:02
https://f1ingenerale.com/wp-content/upl ... image.webp
https://cdn-4.motorsport.com/images/mgl ... etail.webp
https://pbs.twimg.com/media/GWJLpK1WgAA ... name=large
Can you spot any differences in the floor? Tough for me to tell on this angle.
Developer of F1InsightsHub
Re: Ferrari SF-24
Emag wrote:
29 Aug 2024, 13:18
Not on top. I don't think we'll see topside changes anymore this year, on any car. Occasional diffuser change and whatever we can see on the rear keel :mrgreen:
scuderiabrandon
103
Re: Ferrari SF-24
Vanja #66 wrote:
29 Aug 2024, 13:41
Emag wrote:
29 Aug 2024, 13:18
PD confirmed the updates were only fitted to car 55 and then removed (presumably for legality checks). Car 16 here is still in old spec.
