Exactly. We can't judge the ICE efficiency only. It has to be taken as a whole unit. Ie. one could make a super efficient ICE, but it will harm the MGUH production because of less exhaust gasses. And vice versa. So from my point of view it's pointless to talk about peak power. Sustained power is the magic word.
I agree with you on the most on what you said. But there are these said variables and one of them is how much you can harvest in the lap. In WEC 8MJ are possible. And then theres MGUH to MGUK direct connection, which is unlimited. It depends on the track also. It was said last year that Mercedes is capable to directly "connect" MGUH and MGUK and others aren't...harjan wrote: ↑04 Aug 2017, 12:19
Yes, over a race distance more comes into place. Efficiency, harvesting, etc. But on a qualifying lap none of that matters (except for when you have deployment issues as Honda had in 2015 when they ran out of juice around laps like Spa- but those days are long gone).
Qualifying is about low fuel, max fuel rate, full batteries and flat out. And that's exactly what Horner and Bouiller use to make these power comparisons.
Obviously the second one.Well what he means with those figures is that with the 1,5km/L you get 5 KWh less, make more mileage and also you have to carry less weight (fuel). Depends on the calculation and the track. Unless we get the true numbers, it's nonsense to speculate about efficiency.henry wrote: ↑04 Aug 2017, 09:40I think you are being too subtle.
Obviously in conventional vehicle terms the second is more efficient. So efficiency in these terms is how the power is used to move the vehicle
For F1 efficiency is measured by lap time against fuel mass. (I haven't found a good metric for this, but it doesn't matter)
What wuzak is referring to is the power units ability to convert fuel to usable power.
Of course efficiency in lap time depends on how that power is mixed between ICE and MGU-H. And the further deployment of those two to achieve the best possible lap time. Equivalent to your km/L measure.
Most people on this forum don't make those distinctions. They are interested in "peak" power and fuel usage, "efficiency". They don't really make the link Wuzak does, let alone the complexities of deployment.
You are not helping people with their understanding when you, an expert, talk about "peak power" ( an earlier post), or offer confusing examples involving measures of efficiency that have no relevance to this F1 formula.
Its A bs question comparing steak to celery sticks...MrPotatoHead wrote: ↑03 Aug 2017, 22:32What is this Black Magic you speak of!Tommy Cookers wrote: ↑03 Aug 2017, 22:10the crankshaft torque does not propel the car - the torque around the axle does
the 18000 rpm 967 hp NA engine will provide the same axle torque as a current 10500 rpm 967 hp engine does
because the NA engine is geared correspondingly lower![]()
Well he wasn't technically wrong if you are just looking at torque at a specific rpm using his specific numbers.diffuser wrote: ↑04 Aug 2017, 16:28Its A bs question comparing steak to celery sticks...MrPotatoHead wrote: ↑03 Aug 2017, 22:32What is this Black Magic you speak of!Tommy Cookers wrote: ↑03 Aug 2017, 22:10the crankshaft torque does not propel the car - the torque around the axle does
How much HP or torque would that V10 make on a fuel flow limiation of 100kg/h that the present PU have? I'd probably create more power in my twin turbo v6 lincoln MKZ.
They can all direct connect. The Merc just seems to be able to get the turbine to spin both the compressor and mgu-h with enough vigor that they sustain more power for longer periods of time.ziggy wrote: ↑04 Aug 2017, 13:09I agree with you on the most on what you said. But there are these said variables and one of them is how much you can harvest in the lap. In WEC 8MJ are possible. And then theres MGUH to MGUK direct connection, which is unlimited. It depends on the track also. It was said last year that Mercedes is capable to directly "connect" MGUH and MGUK and others aren't...harjan wrote: ↑04 Aug 2017, 12:19
WEC harvests from front and they use motors that are rated at 400-500 hp, so they can harvest a lot through the 13 km lap.
I believe only Singapore is likely to allow the full 2MJ to be recovered under braking from the MGU-K.FW17 wrote: ↑04 Aug 2017, 16:57WEC harvests from front and they use motors that are rated at 400-500 hp, so they can harvest a lot through the 13 km lap.
In F1 the motors are in the back, the rears are generally have only a 3rd of the braking force and the laps are short.
F1 cars can get only about 2MJ (being optimistic) from brake energy recovery
Porsche is using an MGUH and overall a very similar tech as used in F1. Apart from weight ( F1 722kg, Porsche lmp1 875kg) and the K in front the system is similar.FW17 wrote: ↑04 Aug 2017, 16:57WEC harvests from front and they use motors that are rated at 400-500 hp, so they can harvest a lot through the 13 km lap.
