strad wrote:but I bet the FIA dictate an in line 4.
Of course you are perfectly entitled to your opinion. But I would be interested if you can justify it. AFAIK since 01.08.2009 a Concord Agreement is in place again which says the rules are decided by the F1 commission and only rubber stamped by the FiA WMSC. This means the teams and Bernie are the rule making authority. I refer to the bolded part of the below quote.
Motorsport.com wrote:It emerged this week that the broad outline of the sport's future rules has been essentially decided and agreed by the majority of the teams.
According to Italy's Autosprint, the famous Ferrari outfit is not among them.
Instead, the report said the Maranello based team wants Formula One to revert to a 1.8 litre V6 engine design, which would be much easier to adapt from the current 2.4 litre V8s.
Ferrari's engine boss Luca Marmorini reportedly insists there is not enough time to design a completely new engine for 2013 "with the necessary reliability to have only four units (per driver), as they would like", he said.
Marmorini also argues that a 4-cylinder design would require a complete overhaul of the chassis designs.
Amid Ferrari's staunch opposition last year to the proposed budget cap rules, the team threatened to quit Formula One.
In a new interview with Corriere dello Sport, team boss Stefan Domenicali said anyone who thinks F1 would be the same without Ferrari "is wrong".
He warned that, "depending on how the rules are configured", Ferrari is open to seeking new challenges in "Le Mans or the major American championships". report confirms this situation.
It does not come as a big surprise that Ferrari - and possibly some other manufacturer teams as well - oppose a formula that would bring F1 in line with the GRE decisions. It is not in their marketing interests to use the same engine layout as other forms of motor sport. The consequence would be much increased competition by other manufacturers supplying engines to F1. But it is well in the interest of independent teams to attract a maximum of manufacturers and have the most fuel efficient engine configuration. It needs no reminder that at present the voting ratio between manufacturer and private teams is 4:8.
Cosworth and the FiA are other stake holders in this game who have no real decisive voice. I understand the Cosworth position such that they are best pleased by not defining an engine configuration at all but leave it to each manufacturer to compete with his own design in a formula which is severely fuel restricted compared to today. The FiA are also dedicated to the most fuel efficient engine but are open to listen to manufacturers in and out of F1 in order to make the engine industry relevant. With that position both Cosworth and the FiA are probably not fully in line with Ferrari's proposal.
If I look at Luca Marmorini's points I see different merit in them. So lets have a look at what he says.
Luca Marmorini wrote:A 1.8 litre V6 engine design would be much easier to adapt from the current 2.4 litre V8s as there is not enough time to design a completely new engine for 2013 with the necessary reliability to have only four units per driver and year.
I believe that this is not the true reason for the proposed formula. An optimized 1.8L turbocharged V6 would have a completely different engine technology compared to a NA 2.4L V8. The engine rpms would be much lower in a turbo engine with direct injection. As a consequence the bore/stroke ratio would be different, which necessitates different engine and cylinder blocks, the firing order and the crank shaft would be different including the bearing technology. The loads from inertial forces and working forces would be different requiring a totally new design of pistons and connecting rods. The valve trains and ports would be different in a new formula due to the use of variable timing and lift. This would also impact on the cylinder head design. At the bottom line you see that nothing of the old engine would remain. There is no real option to carry anything over from the old formula into the turbocharged downsized formula.
Luca Marmorini wrote:A 4-cylinder design would require a complete overhaul of the chassis designs.
Luca seems to have a point here as the chassis design of the last 20 years was geared towards V engines with 8-12 cylinders and predominantly 90° V-angle. But again a careful examination reveals that F1 is embarking on a completely new chassis design concept anyway. The new chassis are supposed to have ground effect and side pots which are coming much more forward to protect the driver against side impact. Both points have a huge impact on chassis design. There will be more floor area further forward reducing the necessity to have big front wings. There is also the option to have dedicated venturi channels as used by the the American Champ Cars for many years. The slimmer L4 engine format would be beneficial to a chassis design with venturis. So again it turns out that Marmorini's point is not standing up to examination. It simply masks the fact that Ferrari serve their own agenda like everyone else in F1.
