FEE flow does carry some lateral momentum (up to 40kgm per side if we belive in exhaust speed od more then 200m/s). One can use this momentum to push a little against the air rushing to fill the low pressure area under the car. I think dynamic flowlines bending is more appropriate description then virtual skirt, but maybe it's just a semantic thing.Allison clearly states the vortex being formed creates low pressure. This low pressure is used to produce downforce. There is no mention of sealing. I am not sure we have ever heard a current F1 engineer state that there is a sealing effect. We also have not seen any CFD work illustrating this sealing.
Brian
What Allison states is quite obvious - every free vortex creates pressure drop around the axis, simply because particles gain some extra speed (tangential in this case), and this means (as described by bernoulli) that static pressure decrease. If you place this vortex under the floor and keep it alive along the way, this creates described downforce.
