changes are...
-front and rear wing
-floor
-rear brake ducts
AMuS
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
F1 is a delicate balance between aero and engine. The less DF the car generates through the corners the faster it goes down the straights (as a rough generalisation of course) with the holy grail being aero/engine balance.Pany wrote:How increasing drag would be a good sign?
He was talking about drag from a supposedly larger airbox. Nothing to do with DF.Jackles-UK wrote:F1 is a delicate balance between aero and engine. The less DF the car generates through the corners the faster it goes down the straights (as a rough generalisation of course) with the holy grail being aero/engine balance.Pany wrote:How increasing drag would be a good sign?
If in Barcelona, for example, they could only run at 95% of their peak top speed with 60% of their peak downforce then a portion of their optimal lap-time if being wasted. With updates maybe they are able to run at 95% top speed with 70% peak downforce - no loss of straight-line speed but with better speed through the corners.
If Honda have generated enough additional power in the PU and McLaren are happy to sacrifice a small drag penalty from new bodywork (essentially inefficient downforce) it means that the top end HP from the engine has increased to nullify the offset difference.
We know that Honda have spent two tokens on a new turbo aimed at enhancing the efficiency of the hybrid system and that ExxonMobil have developed a new fuel which JB says will be worth around 0.1 secs per lap (around Montreal). Maybe the these updates have had the desired effect giving McHonda a serious boost (excuse the pun ).
Button having the same lap time as a Williams around a power-friendly circuit is a fantastic result. Does anyone have speed-trap data yet?
I would disagree with that looking at those figures...GoranF1 wrote:the Mclaren seems to work better on harder tyre here?
http://www.auto-motor-und-sport.de/form ... 29200.html
