We might be talking about the same thing here, horizontal drag load resulting in a twist-bend of the wing?shelly wrote:@richard: I agree with you on the key being cf layup tailored to meet regulation and deform under aero load. I asked to expensive why he thought drag was critical in this (aerodynamic torsion moment could be enough already).
While expensive underlines drag importance, I would highlight instead the possibility of twist-bend coupling of laminates.
well i´m pretty sure FIA would make their own don´t you think?wesley123 wrote:He doesnt, what he iss aying is that such an idea is unclear. You, and a few others, make it sound like it is so easy to implement, which it obviously isnt, that is what richard meant i think.HampusA wrote:And again with the sneaky snake comments..richard_leeds wrote:See the pics above for how the teams measure these things in real life.
So do we put on the magic sensors before or after we sprinkle the tracks with fairy dust?
Can you make atleast one post without these comments?
Maybe try some constructive criticism instead because those comments doesn´t really help now do they? I´m sorry we had no idea you were the official F1 master who knows everything there is to know.. Give me a break.
How do you know?Does FIA have this system you talk about? Have they even thought about using that system you are talking about?
No and no. How about talking to us like you would want to be talked to yourself?
The nose it does, since the loads put on the Front wing gets carried through to the rest of the car, this energy has to go anywhere you know.Back to reality, Does these tests take into consideration on how much a nose flexes? or how much a FW pivots inwards compared to the general downforce pushing the wing down? Doubt it.
Apart from that, how does that sensor you recalled take the pivot of the wing into account?
I am for a system to ensure this, but a sensor is useless and way too high tech, plus to get realistic readings you need sensors all over the plce, ande these can get kicked off in case of damage.
That is why I am for a much simpler system which doesnt work different, LMP's have been using these for ages, you just add skid blocks in the footplates, by that way this can be regulated way easier, without the need of high tech gadgets all over the place.
I like richard description too. We are talking more or less the same thing, but I think that maybe torsion is more relevant than drag.xpensive wrote:We might be talking about the same thing here, horizontal drag load resulting in a twist-bend of the wing?shelly wrote:@richard: I agree with you on the key being cf layup tailored to meet regulation and deform under aero load. I asked to expensive why he thought drag was critical in this (aerodynamic torsion moment could be enough already).
In either case, I like Richard's above description of the phenomena very much.
Wing main plane's tend to run with a 7.5 to 15 degree angle of attack (that is the chord angle), food for thought. mmmmmmm food.richard_leeds wrote:x - The notion of horizontal, vertical and torsional are mere human constructs to describe the force vector and its relationship with the shear centre of the section. You can use the term "drag" for this thread if you like (in every sense )
It occurs to my rambling mind that could also describe them as normal to the wing chord with an offset. I've excluded excluded torsion from my description. Same result though.
The key (that you call drag and I call torsion) is to apply a force that is not in line with the centre of stiffness
Torsion and drag could be the same force, it just depends on where you resolve them.shelly wrote: I think that maybe torsion is more relevant than drag
Again a very painting description of torsion/twist, induced by a horizontal load, in turn stemming from aerodynamic drag.richard_leeds wrote: ...
The point is that we are talking about an anisotropic structure, it does not have the same properties in every direction, which is why a torsion can result in a vertical movement. In the case of RBR, downwards.Tozza Mazza wrote: ...
The thing that confuses me about all this, is a front wing is made of Carbon Fibre, which is one of the strongest materials on the planet. In physics the other day, my teacher said that it has a young's modulus of 290Gpa, which is very very very very strong.
Modulus of elasticity, so you are talking of stiffness not strength. 290 sounds a bit high. http://en.wikipedia.org/wiki/Young%27s_modulusTozza Mazza wrote:a young's modulus of 290Gpa, which is very very very very strong.
Agree of course. What I want to highlight,as I did not see it in your description, is that it is the laminate that behaves with twist-bend coupling (before the section exists let's say). As expensive has just written.richard_leeds wrote:Thanks for the appreciation. Any more would be most welcome
