Force India VJM07 Pre-launch Speculation
bjpower
bjpower
-1
Re: Force India VJM07 Pre-launch Speculation
There does not seem to be much of an under cut ( under SAHARA) the rear wing seems to have 2 inlets in the side panel. cant remember if they were there last year.
There seems to be something above the last A in SAHARA and next to the O in CLARO. it could just be a reflection.
cant really make much else out
Holm86
247
bjpower wrote:There does not seem to be much of an under cut ( under SAHARA) the rear wing seems to have 2 inlets in the side panel. cant remember if they were there last year.
Those are just the regular gills by the driver well.
And I see a pretty large undercut at the front of the sidepod.
j2004p
j2004p
SilverArrow10 wrote:Is it me or does it look like it has a drag reduction system also. I thought the teams had stopped developing those things.
If you're talking about the secondary intake behind the primary roll hoop, these inlets are often for secondary cooling requirements such as the oil cooler or other items further back in the bodywork.
techF1LES
176
Ok from the larger Pictures is think now it is a pretty "classic" Penis Nose but the Nose Pylons are angled inwards towards the back so from the Side it looks like a smooth Transition.
vas_04614
vas_04614
Force India have also clarified that the VJM07 will be 'officially presented at next week's Jerez test session'.
Me too thinks the 'upper nose' stops where the parts I painted green starts. So the pylons (white) are attached to the upper nose. And the finger (black) is free... like many of the solutions we discussed here..
Matt Somers
Matt Somers
179
I know it's only one image to work with but I decided to jump on it and here's the result: http://somersf1.blogspot.co.uk/2014/01/ ... aunch.html
2 slots/holes in the rear wing endplate now to "bleed off" turbulent air from the wheels. I guess that with the interaction between diffuser, beam wing and rear wing gone, they can allow more turbulent air inbetween the endplates.
Holm86
247
Blackout wrote:Me too thinks the 'upper nose' stops where the parts I painted green starts. So the pylons (white) are attached to the upper nose. And the finger (black) is free... like many of the solutions we discussed here..
http://i57.servimg.com/u/f57/14/79/55/26/vjm07_10.jpg
I agree. Scarbs has tweeted how he thinks it looks like. But I do not agree with him. I also think the pylons is attached to the upper nose.
https://twitter.com/ScarbsF1/status/425947279540117505 https://twitter.com/ScarbsF1/status/425946780761862144
elf341
elf341
Kind of puts the furore over the 2012 platypus noses into perspective. The finger-tip style nose looks awful!
Holm86 wrote: I agree. Scarbs has tweeted how he thinks it looks like. But I do not agree with him. I also think the pylons is attached to the upper nose.
Jep, basically like the second Picture but a bit prettier. So still ugly... :roll:
I think he mislooked himselves on how the pylons bend. Underneath the upper nose they bend inwards, giving an impression they are positioned more inwards altogether.
Yeah the pylons seem to bend inward like the F2012 and F138 pylons... a Venturi?
SectorOne
To me it looks like a "normal" nose. No penis extension and the pylons at the front is extended outwards then tapers inwards the further in you go.
