http://www.f1technical.net/forum/viewto ... 78#p504378 (No reading required)
Look at the first image, notice how the power and torque curves drop off after 10500 RPM (coincidentally where fuel flow first reaches 100kg/hr, prior to that its Q (kg/h) = 0.009 N(rpm)+ 5.5. (so 9000RPM would be 86.5kg/hr).
Because the fuel flow at 10500, and 12000 are identical, what explains the drop of torque and power, the potential energy of the fuel remains the same, the ability to pump air is sufficient. Well, its mechanical losses. That's why they don't bother to rev beyond 12000 or so. Because the drop off in power is too great. It doesn't matter if you have more fuel or not. If you were to add more fuel, the numbers on the side of the graph would simply be higher, the shape of the power band would remain roughly the same.
if you wanted to raise the rev limit, change the formula to Q=0.0075N+5.5, that would make peak fuel flow start at 12600rpm. And the cars would be even slower.
Anyway, this is out of the scope of you and this argument im guessing.
Cheers.
