My definition of a common sense is different then. Why even include theoretical alternative from the future that has nothing to do with this accident in a report about it? Make it a separate study although I'm pretty certain this accident didn't change anything when it comes to cockpits, impacts etc Why would a single specific incident be decisive in adding cockpits anyway, wasn't it about tyres or other smaller objects mostly? This report is a mixture that includes everything: even superlicense and sunset so driver's speed is clearly not the end of it.langwadt wrote:common sense really, treat the disease not the symptoms.It is not feasible to mitigate the injuries Bianchi suffered by either enclosing the driver’s cockpit, or fitting skirts to the crane. Neither approach is practical due to the very large forces involved in the accident between a 700kg car striking a 6500kg crane at a speed of 126kph. There is simply insufficient impact structure on a F1 car to absorb the energy of such an impact without either destroying the driver’s survival cell, or generating non-survivable decelerations.
It is considered fundamentally wrong to try and make an impact between a racing car and a large and heavy vehicle survivable. It is imperative to prevent a car ever hitting the crane and/or the marshals working near it.
if left up to the driver yellow flags are just an opportunity to gain and advantage by slowing less than the guy in
front or behind
As for "the better grasp" (from different post), from conclusions:
1. So there was no working failsafe system at all but is it required or not? 2. Why mix driver's reaction (purely speculative "distracted") with failsafe that didn't work and may or may not have affected the velocity had it worked?7: During the 2 seconds Bianchi's car was leaving the track and traversing the run-off area, he applied both throttle and brake together, using both feet. The FailSafe algorithm is designed to over-ride the throttle and cut the engine, but was inhibited by the Torque Coordinator, which controls the rear Brake-by-Wire system. Bianchi's Marussia has a unique design of BBW, which proved to be incompatible with the FailSafe settings.
8: The fact that the FailSafe did not disqualify the engine torque requested by the driver may have affected the impact velocity; it has not been possible to reliably quantify this. However, it may be that Bianchi was distracted by what was happening and the fact that his front wheels had locked, and been unable to steer the car such that it missed the crane.
