http://www.motorsport.com/f1/news/techn ... es-668712/
Assumption 1. Giorgio Piola's as usual stunning drawings in this article seem to indicate that Ferrari is staying with their original turbo compressor layout they have used for the past 2 seasons - ie keeping the compressor and turbo together, which Renault have used aswell.
Assumption 2. The other 2 PU manufacturers, Mercedes and Honda, are likely to stay with their split compressor turbo layout, with all the power unit and chassis benefits this layout brings: including lower chassis centre of gravity, the compressor is kept cool by because it's not right next to the hot turbo/MGU-H, tighter packaging possible with the aerodynamic benefits this brings, and several more.
Are assumptions 1 and 2 correct? If so, are you surprised Ferrari and Renault did not adopt the split compressor turbo layout after the first season of hybrids, and really surprised it seems like they both will not be adopting it for the upcoming season? After all this layout is the basis of Mercedes advantage because of all the many other benefits it brings that all add up. And Honda are trying to use this layout but make it more compact. I am really surprised personally. I really thought Ferrari would adopt the split layout for this season, the layout change would be easily be possible within the 32 tokens.
