Yes it was a typo. Anyway i doubt they can create shark skin riblets with a paint. A rough coating can create a similar effect but to get a real benefit you need a specific crafted surface not just some paintTarkonte wrote: ↑08 Feb 2019, 11:46
It's a mistyping. Article speaks about an experimental A320.
Furtherly, I remember some papers about a rough coating advantages in last monohull America's Cup boats, always reporting a tight relation with shark skin behaviour also at low speeds. The same for some military applications (SSBNs).
The trick with the double stacked wastegate pipes is that the lower one of them is a dummy. No exhaust flows throught it. All the dumped exhaust flows through the top one so the velocity near doubles. And since it is now closer to the bottom of the rear wing you get s stronger effect.Sevach wrote: ↑08 Feb 2019, 18:54https://www.motorsport.com/f1/news/ferr ... t/4334541/
Speculation on the stacked exhaust.
Multiple grains of salt... but...
Interesting, that's the first time I read a solid reason why it would make an actual difference. How do you know about it?PlatinumZealot wrote: ↑09 Feb 2019, 17:22The trick with the double stacked wastegate pipes is that the lower one of them is a dummy. No exhaust flows throught it. All the dumped exhaust flows through the top one so the velocity near doubles. And since it is now closer to the bottom of the rear wing you get s stronger effect.Sevach wrote: ↑08 Feb 2019, 18:54https://www.motorsport.com/f1/news/ferr ... t/4334541/
Couldn't they just use a single waste gate to the same effect?PlatinumZealot wrote: ↑09 Feb 2019, 17:22The trick with the double stacked wastegate pipes is that the lower one of them is a dummy. No exhaust flows throught it. All the dumped exhaust flows through the top one so the velocity near doubles. And since it is now closer to the bottom of the rear wing you get s stronger effect.Sevach wrote: ↑08 Feb 2019, 18:54https://www.motorsport.com/f1/news/ferr ... t/4334541/
Gilles27Kimi7 wrote: ↑09 Feb 2019, 18:43Couldn't they just use a single waste gate to the same effect?PlatinumZealot wrote: ↑09 Feb 2019, 17:22The trick with the double stacked wastegate pipes is that the lower one of them is a dummy. No exhaust flows throught it. All the dumped exhaust flows through the top one so the velocity near doubles. And since it is now closer to the bottom of the rear wing you get s stronger effect.Sevach wrote: ↑08 Feb 2019, 18:54https://www.motorsport.com/f1/news/ferr ... t/4334541/
you can use singlePolite wrote: ↑09 Feb 2019, 18:50Gilles27Kimi7 wrote: ↑09 Feb 2019, 18:43Couldn't they just use a single waste gate to the same effect?PlatinumZealot wrote: ↑09 Feb 2019, 17:22
two tubes are mandatory by regulations.
I think here is only a matter of weight savings: one pipe is so short.
Engine exhaust systems must have only a single turbine tailpipe exit and either one or two
wastegate tailpipe exits which must all be rearward facing and through which all exhaust gases
must pass
The wastegate exits have to be sized accordingly to not be a bottleneck otherwise it won't be able to divert enough gas from the turbine, and you get boost creep.
I believe him, the design is to make the lower one just a small "intersection" out of the top one, only the top one is directly connected to the wastegate itself.bosyber wrote: ↑09 Feb 2019, 18:41Interesting, that's the first time I read a solid reason why it would make an actual difference. How do you know about it?PlatinumZealot wrote: ↑09 Feb 2019, 17:22The trick with the double stacked wastegate pipes is that the lower one of them is a dummy. No exhaust flows throught it. All the dumped exhaust flows through the top one so the velocity near doubles. And since it is now closer to the bottom of the rear wing you get s stronger effect.Sevach wrote: ↑08 Feb 2019, 18:54https://www.motorsport.com/f1/news/ferr ... t/4334541/
