Capharol wrote: ↑29 Nov 2019, 20:29
search wrote: ↑29 Nov 2019, 18:38
Capharol wrote: ↑29 Nov 2019, 17:06
Soft:
Hamilton - 1:43.093
Verstappen - 1:43.156
will check if these numbers are correct
apart from the first lap (where they were equally fast), Verstappen on Softs was about half a second slower than Hamilton per lap, for the rest of the stint, as far as I can see. So those numbers can't be quite right?!
check the one below me.... you'll see they are right and Toni Sokolov didn't took the 44.xxx in his calculation ... i did, because to me a 44.xxx isn't a really bad lap even due to traffic or do you think all other will go out of the way immediatly when Hamilton comes behind them.... not really, so a 44.xxx is a represantative lap IMO
yeah, well, technically you are right, but only because you advantage Verstappen for running one lap less. If you compare them vice versa, you can see that the gap was miles bigger:
Hamilton - Verstappen
1:42.535 -1:42.614 +0,079s
1:42.197 -1:42.705 +0,508s
1:42.759 - 1:43.332 +0,573s
1:48.566 - 1:46.687 too slow too include
1:43.326 - 1:43.974 +0,648s
1:44.647 - P 1:46.560
P unknown
