Renault F1 R.S. 20 Speculation Thread
PowerandtheGlory
PowerandtheGlory
Re: Renault F1 R.S. 20 Speculation Thread
Emag wrote:
18 Feb 2020, 01:29
djos wrote:
18 Feb 2020, 01:24
Iowa wrote:
17 Feb 2020, 14:24
From Reddit
https://i.redd.it/5tak4mh76hh41.jpg
If you zoom right in on the right-hand wing, you can see a very radical twist in the top element that appears to be designed to very forcibly drive outwash! It should be interesting to see how well this works compared to other solutions - they seem to have prioritized downforce over drag (unlike Ferrari).
https://i.imgur.com/iu91ko9.png
They had that last year. It came with an upgrade towards the end of the season.
Zoom in to see their front wing at brazil last year (right side has better light) https://i2.wp.com/f1chronicle.com/wp-co ... C435&ssl=1
Another thing that I would like to point out. I am no aerodynamic expert btw, so don't take my word for granted. Forcing the air to go to a certain position abruptly like Renault is doing is not the best option because the air will lose a lot of energy that way. They are probably using that because it's the best compromise for them at the moment in terms of front downforce and outwash generation.
Im no expert either but the front wheels are a nightmare for aero guys, this step might throw the air higher up the wheel where it is dirupted and then flows over and hopefully is pulled back into the bargeboard area and diffuser by the fast air running under the front wing to the cape and along the nose section, accelerating and causing a venturi effect, pulling the air travelling behind the wheel into that area re-attaching it to the side of the car and supercharging the diffuser.
The front wing may have been stalling because the air was being forced at the wheel and being pulled over and under causing lift and/or stability issues. This clearly throws the air up and over... most definately a different approach to ferrari etc.. and yup it would seem high D. it will be interesting to see the Low drag Canada and Monza version wing..
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
Iowa
Iowa
Finally some spy shot from yesterday !
gosswilliams75
bad pics coming through..
via @Peke_Formula1
PowerandtheGlory
PowerandtheGlory
Thanks for the photos.. the Bargeboard area is too dark to see, but at least we can see suspension points a bit better and the rear of the car looks neat, quite bulky around the middle which seems to be a Renault PU thing- bit like the Mclaren, but it looks tidy. =D>
f1rules
f1rules
635
yeah looks like a renault/mclaren feature, but thats also where the turbo is no? it must be one gigantic turbo this year since theyre both so chubby in that area
Emag
Emag
137
Tomorrow we finally get high res pictures of this car. Why didn't they post anything online when they had the car ready is beyond me. Those renders were a complete waste of time too. Worst car launch of the year imo.
Developer of F1InsightsHub
Compared to 2019
Emag
Emag
137
Blackout wrote:
18 Feb 2020, 13:33
Compared to 2019
https://i.imgur.com/WdyQqaj.png
Seems like the sidepods are a little slimmer, but they still have that wide af airbox. Can't make out too many details from those pictures though.
PowerandtheGlory
PowerandtheGlory
Emag wrote:
18 Feb 2020, 13:32
There is no 'testing livery' to be seen and the renders were nothing. I don't even think there's more white on the car.. its just a copy and paste colour from last year.
So they kept everyone in suspense forrrrrr..... what? Pointless
IMO this bodywork is a bit tighter than 2019 in atleast two areas: the Renault sticker at the back (like the render suggested)* and at the top of the RCI sticker at the front. Maybe that's why the bump near the "edge" sticker looks bigger. The bodywork looks a bit more shrink-wrapped around the internal organs of the car.
*the render is accurate until now. The car do have at hinner nose, a boomerang and updated mirrors.
So I was right and that's the most important point 8) :mrgreen: :arrow:
PowerandtheGlory
PowerandtheGlory
Emag wrote:
18 Feb 2020, 13:34
Blackout wrote:
18 Feb 2020, 13:33
Compared to 2019
Id like a head on comparison to see the suspension mounting points. I think they've move up, slight change in the clamshell shape compared to last year - the rear looks neat- but again need to see more. And im guessing or i hope they've gone for a letterbox intake to match the top 3 - I read somewhere that Renault's PU uses a different cooling intercooler to the other engines - i.e air cooler rather than wet charge cool.. don't quote me on that..
the EDGE
the EDGE
68
PowerandtheGlory wrote:
18 Feb 2020, 13:41
Emag wrote:
18 Feb 2020, 13:34
Blackout wrote:
18 Feb 2020, 13:33
Compared to 2019
Maybe Renault have had their marketing budget slashed
PowerandtheGlory
PowerandtheGlory
the EDGE wrote:
18 Feb 2020, 13:42
18 Feb 2020, 13:41
Emag wrote:
18 Feb 2020, 13:34
Most teams expected to spend more this year 'before' the cap comes in.. on all sorts of things..
AMG.Tzan
44
Looks like they've reduced their rake quite a lot...last year they had a lot of rake! Or is this some kind of trick system to gain straight line speed??
If not then Renault looks to have gone Mercedes's way of slim nose with cape and without the thumb and low rake!
