Racing Point RP20
Re: Racing Point RP20
Via AMuS
Otmar confirms that they used photos and a bit of intuition to copy the Mercedes.
PowerandtheGlory
PowerandtheGlory
PlatinumZealot wrote:
26 Feb 2020, 17:24
Of course you did, and apart from a photo side on to the merc car- you also got a photo from underneath and behind the bargeboard and under the Front wing and a photo from all angles of the rear suspension... What a load of Tosh
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
cplchanb
cplchanb
PowerandtheGlory wrote:
26 Feb 2020, 17:37
26 Feb 2020, 17:24
you do seem to forget that these people have exponentially more access to view other teams' cars than you would ever have in your lifetime as a normal muggle from the grandstands. Not to mention they use the same factory windtunnel so "pictures" are more easily to come by
PowerandtheGlory
PowerandtheGlory
cplchanb wrote:
26 Feb 2020, 17:41
26 Feb 2020, 17:37
26 Feb 2020, 17:24
Fine i'll take the bait...
I'm not forgetting - merely using photographs (and intuition?!?!) to re-create something as detailed as a bargeboard area which includes fully CAD 3D modelled parts and parts that cannot only be viewed with sections of the bargeboard area removed...!!??
AND get them perfect as per the photos
AND get the exact distances between sections when viewed
AND know exactly the thickness of the stress/load bearing parts and the mounting points (which are hidden) to connect to the chassis Tub (which you just to happen to be using)
AND get a photo of the areas of the car which you cannot see from 'any humanbeing camera angle..
AND to test the "newly designed car'' last week with no obvious structural damage to parts they had to 'copy' from photos...
- I'm actually staggered at your naivety
Hashtag-Mugglelife
Drops mic and walks off..... into the sunset.... with an icecream :wink:
nzjrs
26 Feb 2020, 17:58
Hashtag-Mugglelife
When you put it like that, it must be impossible to design bargeboards with intuition and without photos! :wink:
26 Feb 2020, 17:37
26 Feb 2020, 17:24
You don't understand. you really don't understand how skilled these people are. They don't need to see every detail nor every piece of the jigsaw to complete the picture. It's not like they are designing an engine - It's all external surfaces. These are immensely intelligent and experienced engineers, they already know how the different flow structures work and what is required, they just need a few hints to see where to place what.
jjn9128
779
26 Feb 2020, 17:58
This tin foil hat stuff has to stop. McLaren were fined $100m and excluded from the championship for copying Ferrari - and that's before the listed parts section was added to the rules (I know that's a case of corporate espionage so it's slightly different). But IF Mercedes had given Force Point India Racing access to their CAD to copy the non-listed parts you can bet the FIA would come down pretty damn hard on them. For Racing Point the risk is maybe worth it to get some decent results and inside knowledge of the big team, even though it doesn't carry forward to next year, but for Mercedes there's no chance they're going to risk the bad PR, big fines, or expulsion from the championship to help a midfield team maybe get some podiums.
#aerogandalf
Big Tea
99
Would that be photo as in photocopy ?
:D
PowerandtheGlory
PowerandtheGlory
jjn9128 wrote:
26 Feb 2020, 18:08
26 Feb 2020, 17:58
We'll see about that, currently Merc's silence is especially golden... I mean i cant see any advantage to Merc of having a Really quick Merc type car in 3-4-5 places... hmmmm (wink wink, nudge nudge, let Lewis past in Monaco - he's in a difference race to you- coded radio message)
PowerandtheGlory
PowerandtheGlory
26 Feb 2020, 18:07
26 Feb 2020, 17:37
26 Feb 2020, 17:24
I agree they are supremely intelligent, and they have access to wind tunnels and so forth.. but you cannot sit there and listen to the TP saying it was based on photos and intuition...
These designers DON'T WORK THAT WAY... ! A family member of mine works in automotive engineering on large scale national projects... to start a project like that from blank sheet with photos only and to the scale and complexity is impossible - there is some handover of knowledge, you cannot go from blank page with photos to that... with perfect and with 100% working correlation - you have had HELP somehow...
Edit- Sorry about the CAPITALS ..!!
Racer X
jjn9128 wrote:
26 Feb 2020, 18:08
26 Feb 2020, 17:58
So then I doubt that Mercedes has done anything illegal specially if the Technical Director of Pink Mercedes is going around so confidently talking about how they copied Silver Mercedes then i'm sure everything is perfectly legal.
RedBull Racing Checo//PEREZ
Big Tea
99
Can I get a C Class RP?
PowerandtheGlory
PowerandtheGlory
Racer X wrote:
26 Feb 2020, 18:25
jjn9128 wrote:
26 Feb 2020, 18:08
26 Feb 2020, 17:58
The PR is the silly thing, they have completely failed to manage the situation.
It started off as - 'adopting a similar concept' and its gone full spectrum
to 'we copied it from photos and intuition'
Its all a bit Basil Fawlty...
PowerandtheGlory
PowerandtheGlory
Big Tea wrote:
26 Feb 2020, 18:29
No but you can get an 'Aston' with a Merc engine ..............vantage anyone??........... :lol: :lol: :lol:
You could get 2 more MERC astons next year =D>
