Alpine A523
Re: Alpine A523
Alpine dropped the whole sidepod, not just the waterslide. The top SIS almost protrudes from the bodywork over its entire length.
johnny comelately
johnny comelately
110
Re: Alpine A523
Blackout wrote:
23 Feb 2023, 13:47
https://pbs.twimg.com/media/FppdmiSWYAU ... =4096x4096
And moved back?
Re: Alpine A523
johnny comelately wrote:
23 Feb 2023, 13:49
Blackout wrote:
23 Feb 2023, 13:47
And moved back?
I dont think so.
The sidepod inlet is more forward.... maybe the cokpit is more backward...
I think Alpine too created that small extension/keel on the lower nose edges to mount the bottom wishbone trailing arm lower (yellow arrow) (like Ferrari & RB/AT)
#downwash
Re: Alpine A523
Blackout wrote:
23 Feb 2023, 14:31
23 Feb 2023, 13:49
Blackout wrote:
23 Feb 2023, 13:47
And moved back?
I dont think so.
#downwash
https://pbs.twimg.com/media/FpprvEyWAAA ... name=large
Nice spot on the extension to the keel. Did they all do this independently, or did someone have that in 2022 and others have followed suit?
Re: Alpine A523
RB had that AFAIK.
(but my eyes might be deceiving me here, we need more pics : P )
*Maybe Alfa too
Re: Alpine A523
A nice pic of the new centerline cooling system which looks smaller/simpler and not horizontal anymore , + the much-easier-to-access new rear suspensions (also thanks to the different bodywork).
The new anti-roll bar (the cylinder just above the stay) is also better integrated than 2022 and doesn't make the bodywork wider.
📸Albert Fabrega
Re: Alpine A523
The old anti-roll bar (below) was protruding and made the bodywork wider there.
The new one is in the shadow of the cooling system etc, above the gearbox.
Re: Alpine A523
Yes it seems Alpine added a vein to the rear wing endplate to manage the airflow / tire wake there.
I dont recall seeing this solution on other '22 cars.
--> the good old innovative spirit of Enstone is slowly coming back.
Re: Alpine A523
2022 GB vs today
Aside from that vein, the lower end plate corners are more intricate than usual, and more ''3 dimensional'
That's a sensible area of the car.
(blue arrow - darkened)
The floor bulges they added in Singapore are visible here (black arrow)
Andi76
Andi76
446
Re: Alpine A523
According to an Alpine Engineer they are indeed 'extremely" underweight. They can play with 10kgs of ballast. Usually a massive advantage!
Re: Alpine A523
Andi76 wrote:
23 Feb 2023, 21:18
Source? (a journo or an insider?)
I trust your infos, this is just to be able to quote this : )
Andi76
Andi76
446
Re: Alpine A523
Blackout wrote:
23 Feb 2023, 21:46
Andi76 wrote:
23 Feb 2023, 21:18
This comes from an insider. Actually a very high ranking engineer of Alpine.
Re: Alpine A523
Blackout wrote:
23 Feb 2023, 13:47
Yeah I noticed that nnd I noticed what you said about the water slide retaining somewhat of an S shape.
Re: Alpine A523
Andi76 wrote:
23 Feb 2023, 22:48
Blackout wrote:
23 Feb 2023, 21:46
Andi76 wrote:
23 Feb 2023, 21:18
Thanks. This means the Alpine is near the minimum weight of the minium weight*?
*the minimum weight that you have to have on the front axle (0.455) and the rear axle (0.540 or Something), which gives you extra 12kg of weight to play with on the paper?
Re: Alpine A523
A523 boat tail looks slimmer to me.
& the diffuser shape is different, with different kick lines & a steeper climb in '23.
& thx to my X-ray goggles, I think Alpine slimmed down the base of their GBox casing, thanks to the relocation of suspensions.
📸 Thx to @racefansdotnet
