2009 Testing - March (Jerez & Barcelona)
ESPImperium
ESPImperium
64
Re: March Testing Thread 2009 (Jerez & Barcelona)
Ive not heard much about graining from RB yey, maybes the pull rod suspension is there to counteract that.
RacingManiac
RacingManiac
ESPImperium wrote:Ive not heard much about graining from RB yey, maybes the pull rod suspension is there to counteract that.
wha?! :wtf:
Moanlower
Laptimes from Alonso, Raïkkonen and Hamilton on March 4th. Unfortunately no info on what tyres they were on, let alone fuel loads.
Alonso
http://www.profacil.net/F1/Tests/Tests0403ALO.html
Raïkkonen
http://www.profacil.net/F1/Tests/Tests0403RAI.html
Hamilton
http://www.profacil.net/F1/Tests/Tests0403HAM.html
Losers focus on winners, winners focus on winning.
joseff
Diesel wrote:Everyone is complaining about rear graining apparently, it's a cock up with the dimensions of the tyres or something... The rear tyres should have been bigger with the move to slicks...
Removing the grooves effectively adds 4" of width per tyre. This is a bigger percentage change at the front at the rear, therefore moving the grip balance forwards.
megz
Moanlower wrote:Laptimes from Alonso, Raïkkonen and Hamilton on March 4th. Unfortunately no info on what tyres they were on, let alone fuel loads.
Alonso
Raïkkonen
Hamilton
What's with those times? Kimi just went up down up down up down on one run?
chasefreak
chasefreak
wats going on here.. got these pics from todays test i think
mattclinch
Hamilton stopped on track with a failure.
BMW engineer then tried to stick his nose all around the car as they were offloading it from the truck and it got a bit heated apparently!
marinopc
marinopc
mattclinch wrote:Hamilton stopped on track with a failure.
That's the reason why everybody is looking the nose of the Mclaren. What's that gadget¿?
axle
axle
marinopc wrote: That's the reason why everybody is looking the nose of the Mclaren. What's that gadget¿?
Ferarri had the same aero piece from launch.
- Axle
McMacca
McMacca
Alonso
Raïkkonen
Hamilton
As said, dont know tyres, fuel loads etc but it seems that over a stint, the ferrari and mclaren are faster than the Renault, even though Alonso set fastest time overall.
Would love to see more data, if LH can get some longer runs in today.....
marinopc
marinopc
And that kind of bulb??
Thef1.com reports that Mclaren is having a lot of problems today. Hamilton doesn't finish the stints and he went into the box to adjust the wing several times. They're still running the '08 rear wing and using the green painting another time! Problems for Mcca guys...
Rikhart
Rikhart
Id say this late into the pre season, they are having MAJOR problems. Not only is it not reliable, pace is bad as well. Do we finally get to see lewis with a dog of a car? That would be fun.
Sawtooth-spike
Alot of fuss over nothing?
we can see Ferrari are running the same thing.
Mclaren are using the end plates to push air around the tires, so i am gussing this is helping with that maybe linking up with those odd hubs of theres.
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
Moanlower
It's also where the mechanisme sits to adjust the wing.
Here's a clear pic of the temperature stickers on the Ferrari.
kilcoo316
kilcoo316
21
Shaddock wrote: This was definitely McLaren he was referring to.
I stand corrected - thank you.
It must have been the 2004 BAR performance that came from nowhere... they didn't understand it and lost it again (the one I was thinking of - 'cos it was def talked about).
