bhallg2k wrote:
Therein lies the crux of the disagreement, it seems. I'm OK with that particular advantage being hampered, because the advantage is hampered by a completely natural occurrence. Just as I unconsciously accept that gravity will ultimately keep the cars on Earth, I accept that modern Formula 1 cars are constructed in such a way that overtaking is made more difficult. I make no distinction between those truths, because both are natural.
Natural? One is the core of sport (gravity) the other is a product of a set of rules..there's nothing natural in the later;
I consider DRS to be a sort of so-called "victory ballast" which gets in the way of the teams who most competently exploit those rules. In a sport which measures itself by tenths and hundredths of a second, because so much goes into gaining those tiny fractions, it's beyond my comprehension that it's considered OK, for the sake of a "better spectacle," to insert an element into the sport for the sole purpose of deadening the impact of those fractions. I don't like it.
Where do you see DRS is hampering technological competition??? DRS is there to recover a side effect of the rules set not to recover a side effect of technological competition.
There's no link between them...unless you consider desirable that a team put technological effort into making overtaking harder by disturbing wake..
You know, what you are saying is a bit like if you'd find abnormal a soccer player without a ball in his feet runs faster than one with arguing this negates the sprint training of players.
Yes, the sole purpose of the rules governing the use and construction of tires is completely for a "better spectacle." I accept that with the same ease that I accept gravity and wake disturbances because every team is free to avail themselves of their interpretation of those rules at any time. A universal rule is natural.
The leading car will never be able to use DRS. Ever. It's not universal, thus is unnatural in my eyes. That's simply how I see it and why I'm so vehemently opposed to DRS.
"Chris" are tall; So people not called "chris" aren't tall? Of course not.
I think you mess up a bit with terminology and concepts there;
Taking it another way around, a non winged series is also unnatural to you since the leader will never benefit from slipstream thus it is not universal...
@machin:
Shorter braking distance (i.e: Higher deceleration) makes things harder because the reaction time is fixed; But in fact it is not at overtaking someone that it makes it harder, in fact it makes it easier; where it is harder it is not to end you outbraking maneuver straight into the gravel/wall. See:
Imagine two cars traveling at 100m/sec; in a situation A the two cars have 2g's of deceleration (20m/s²) and in situation B double that, 4g's (40m/s²).
One driver (1) tries to outbrake (2) and reacts in the shortest time possible, let's say 0.1sec
In both situations then 1 brakes 0,1 sec later than 2.
In situation A after 0,1 sec since 2 braked, 1 has traveled 0.1*100=10 meters, 2 has traveled 9.9 meters (the calculation for that is bit more complicated);
In situation B after 0,1 sec since 2 braked, 1 has still traveled 0.1*100=10 meters, but there 2 has traveled 9.8 meters.
Of course since it taken at a very short time reference it seems not so big but look at the numbers after 2 seconds:
Situation A: 1 has traveled 200 meters, 2 160 = 40 meters between them;
Situation B: 1 has traveled 200 meters, 2 has traveled 120= 80 meters between them;
You can see the distance doubled between them. You could say so what? The problem is when you have limited room for operation that is when you start to look at the ratio of distance difference between cars/total braking distance.
This ratio translates how much time you have to succeed in your outbraking maneuver;
Since braking distance in situation B decreases while distance difference increases you can easily see the ration will be greater and greater meaning less time to react, If after 2 seconds i'm 80 farther than my opponent on a 100 meters braking distance this will be harder for me that if i'm 40 meters away from him in a 200 meters braking distance.
Now...hum as i say..i don't see any problem at all with outbraking..a major part of the overtakings in F1 is done on braking..
And DRS makes it even easier since the DRS activated car has higher top speed thus longer braking distance (thus more room).
