That's what I meant when I said MGU-H can control engine vacuum. If the MGU-H loads the turbine under engine braking to prevent the compressor from providing any boost to the cylinders you could get some serious vacuum.Brian Coat wrote:Of course the strategy around MGU-H energy transfers during decels will also affect this.
I don't think the teams can. Isn't there a rule that stipulates that all gasses that flow through the compressor must flow through the exhaust. I'm not sure if it mentions if it has to flow through the ICE and turbine though.PlatinumZealot wrote:Or you can use a blow off valve. Not sure if teams use this though.
