Re: Renault V6 Power Unit
Why would Mercedes waste time and resource when they could just easily buy a proven concept?
The jet ignititer is just another component like a sparkplug, injector or a valve. It is wiser to work with mahle to design one for you than wasting time and resources on it. Imagine the years of research and testing put into that igniter alone....
You mean besides the patents, the licensing, and the fact that they're kicking everyone's butts?
Why buy a steak when you own the cows, and the butcher, and the cook?
Saishลซ kลnฤ
Godius
186
FoxHound
55
PlatinumZealot wrote:Why would Mercedes waste time and resource when they could just easily buy a proven concept?
Mercedes have been toying around with this idea in their road cars for a long time now, since around 2005.
DiesOtto used spark plugs but had a "energy saving" mode(Controlled auto ignition) in low demand conditions which did not require the spark plugs. A variation of compression ignition I believe.
http://www.greencarcongress.com/2007/09 ... enz-i.html
This engine also had variable compression ratio technology, which was implemented to boost efficiency.
So it's no stretch of the imagination to see Mercedes having something similar to Mahle, bearing in mind the direction of their research in improving combustion efficiency. So while the above is not evidence, it certainly is er....smoke to the fire? :D
JET set
scarbs
scarbs
393
Merc have denied both HCCI, Mahle involvement and a pre chamber ignition.
There are many means to ignite a largely lean mix in a combustion chamber . Petronas are closely involved, which could link a lean GDI tech called Hyboost, part developed by Ricardo and Petronas.
But Merc remain tight lipped about all of this, but do suggest it's their own tech in there, other than saging 'it' is an outwardly conventional lay out, refined for the lean burn tech.
Brian Coat
Brian Coat
99
Yes. That Ricardo/Petronas work was discussed on here two years ago and it may be relevant, if only indirectly.
But we're all speculating, of course :D
I doubt patents/royalties have anything to do with what people are/aren't using?
scarbs wrote:Merc have denied both HCCI, Mahle involvement and a pre chamber ignition.
They will deny. They will never tell us what is inside that engine. But the clue is that the mercedes engineers who went to ferrari and renault spilt the beans so we can loom on those engines to make a good guess what Merc has.
even in the v10 era we were never told much.
hardingfv32
hardingfv32
Renault lack of coin usage. Does that indicate they are working on an engine that does not fit in the current cars?
Brian
zack!
zack!
hardingfv32 wrote:Renault lack of coin usage. Does that indicate they are working on an engine that does not fit in the current cars?
Brian
For me this is more because they want to maximise the 2017 motor, so they put all ressources on it (ingineers and test benches). All the things that distract them to that objective is put aside. I think they work on software and fuel for 2016 spec only. Something is planed for singapour (if i understood well helmut marko today on sky).
lio007
320
So PU-Update on injection and fuel:
https://twitter.com/tgruener/status/772479400877195264
Juzh
161
3 tokens spent.
carisi2k
27
Didn't Red Bull put a new engine in the cars this weekend?
Pierce89
Brian
Is he back?
โ€œTo be able to actually make something is awfully niceโ€
โ€œI've got to be careful what I say, but possibly to probably Juan would have had a bigger goโ€
ME4ME
79
lio007 wrote:So PU-Update on injection and fuel:
..and RB12 upgrades, this late in the season. Probably some of the last I guess.
