[KVRC] Khamsin Virtual Racecar Challenge 2016
CAEdevice
49
Re: Khamsin Virtual Racecar Challenge 2016
Alonso Fan wrote:Thanks
Jeez man that must have taken a large chunk of your wallet :P
Jokes aside, so if I get it working i should be able to half the time roughly. So about 14 hours instead of 24...
It is the workstation I use for FEM simulations at work: based on second hand componenets (CPU, motherboard). The most expensive part were (in 2014) the RAM kit (8x8gb) and the Quadro 2000 graphic board.
Most of times, the multicore simulations with OCCFD take 6/7h (instead of 5h) because other simulations (ProMechanica) run at the same time on the machine.
CAEdevice
49
The bottle neck with the simulations of the KVRC is the RAM space: 8gb is not enough. 16 is ok.
Alonso Fan
Right, I see. Can it not be optimised to run at lower ram? I only have 8gb
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
CAEdevice
49
You could try including the front and rear wing into the body component (a finer mesh is used for parts including the word "wing"). I am not using the "front wing" component at the moment.
Alonso Fan
Yes, I am currently doing that. I currently have an analysis running so let's see how it goes
SHR Modding
Youtube
Twitter
Discord
CAEdevice
49
What about the light mode of occfd? DR and DF are quite accurate, only the cooling performance is badly approximated.
RicME85
52
Worth mentioning what I found last year....when simulating just a wing profile for the thread Machin and I did, the Test option gave near identical results to the others.
CAEdevice
49
RicME85 wrote:Worth mentioning what I found last year....when simulating just a wing profile for the thread Machin and I did, the Test option gave near identical results to the others.
"test" or "light" option?
Alonso Fan
How much does the light option cut time by?
SHR Modding
Youtube
Twitter
Discord
RicME85
52
I used the Test AWS option and compared with the full AWS option and it was less than 10N difference iirc
Alonso Fan
right, so I ran a successful occfd analysis in parallel. but post processing didn't complete, do I have no values for df/drag etc
how do I get the values from paraview?
SHR Modding
Youtube
Twitter
Discord
CAEdevice
49
The dr/df values are written in the text files of the postprocessing folder (or in the log)
Alonso Fan
Thanks, and what about cop?
SHR Modding
Youtube
Twitter
Discord
CAEdevice
49
The COP os not included into the logs. I often have that post processing issue, so I compute it from the force and moments (with an approximation about the vertical position of the drag).
We should ask Julien wich algorithm is used by OCVFD.
Alonso Fan
Ok, thanks. I'm running a light simulation to quickly check cop. Looks like I have a slow car. I'm not getting enough out of my diffuser, but I have not sacrificed cooling, so let's wait and see
SHR Modding
Youtube
Twitter
Discord
